If i were to use 4 or more sundown 3000's, does the BR out work for daisy chaining multiple amps together, or is it only for strapping 2 amps together?
Its only for strapping two amps together :)
dont daisy chaining those amps.
so how would i wire up more than two amps without havin to split my rca wires which would lower the voltage from the rca's
Technically you won't lower the voltage - in parallel circuits the voltage is the same.
Have never had any issues splitting them to run two strapped pairs :)
thats wat i had thought before, but i talked about splitin the sub out from the hu to two amps on here before and i was told it would split the voltage. and when i hooked it up like that it did seem to make the sundown amp put out less power so i had to turn up the gain
Edited by fritosaregood
then grab a line booster.
ive heard using those creates more noise in the signal along with increased voltage. another possibility is a bass reconstructor, it would work for increasing my voltage from 4 to 8, and help with makin music from my zune sound better, but it would get expensive if i needed more than 1.
I read a post on here a few weeks ago about the car that went to the finals with 16 saz 1500s, do you know how the rca's on that could have been wired
Moving. :)
I wouldn't be concerned with a line driver adding noise in your subs.. you'll never hear it.
You might be able to get an audiocontrol overdrive cheaper. Ideally, you'll luck out and get a matrix cheap. 1 pair in and up to 3 pairs out.
The Maxx-Link is a lil more than a line driver. Thats just one of its features. Its technically a strapping module and its output voltage is adjustable.
