Posted October 21, 200818 yr If i were to use 4 or more sundown 3000's, does the BR out work for daisy chaining multiple amps together, or is it only for strapping 2 amps together?
October 21, 200818 yr Author so how would i wire up more than two amps without havin to split my rca wires which would lower the voltage from the rca's
October 21, 200818 yr so how would i wire up more than two amps without havin to split my rca wires which would lower the voltage from the rca'sTechnically you won't lower the voltage - in parallel circuits the voltage is the same.Have never had any issues splitting them to run two strapped pairs
October 21, 200818 yr Author so how would i wire up more than two amps without havin to split my rca wires which would lower the voltage from the rca'sTechnically you won't lower the voltage - in parallel circuits the voltage is the same.Have never had any issues splitting them to run two strapped pairs thats wat i had thought before, but i talked about splitin the sub out from the hu to two amps on here before and i was told it would split the voltage. and when i hooked it up like that it did seem to make the sundown amp put out less power so i had to turn up the gain Edited October 21, 200818 yr by fritosaregood
October 21, 200818 yr Author then grab a line booster.ive heard using those creates more noise in the signal along with increased voltage. another possibility is a bass reconstructor, it would work for increasing my voltage from 4 to 8, and help with makin music from my zune sound better, but it would get expensive if i needed more than 1.I read a post on here a few weeks ago about the car that went to the finals with 16 saz 1500s, do you know how the rca's on that could have been wired
October 24, 200818 yr Author MaxxLink is your friend. I love mine and its not that expensive.What is MaxxLink?
October 25, 200818 yr MaxxLink is your friend. I love mine and its not that expensive.What is MaxxLink?Its a line driver.. more info here:http://www.maxxsonics.com/hifonics/sigproc_ipod.html
October 25, 200818 yr I wouldn't be concerned with a line driver adding noise in your subs.. you'll never hear it.
October 26, 200818 yr You might be able to get an audiocontrol overdrive cheaper. Ideally, you'll luck out and get a matrix cheap. 1 pair in and up to 3 pairs out.
October 26, 200818 yr The Maxx-Link is a lil more than a line driver. Thats just one of its features. Its technically a strapping module and its output voltage is adjustable.
