Posted October 27, 200817 yr While driving my amp turned off and inspecting it I found that all four fuses on the amp were blown.What all could have possibly caused this?
October 27, 200817 yr While driving my amp turned off and inspecting it I found that all four fuses on the amp were blown.What all could have possibly caused this?Fuses pop because their limit has been surpassed for a predetermined amount of time.Thus. your fuses on your amp popped because they drew/received more amperage than they're rated for for x number of seconds.Loose power wire or ground? Something blown on the amp? Replace them, and see if they pop again.
October 28, 200817 yr Author my remote wire was a little loose but I don't think that it draws enough to cause all four to blow.. I was cranking it up pretty hard so I don't know.. the fuse from the battery didn't blow. I replaced them for now but I still have no idea what caused it. Thanks for the reply though
