Posted November 16, 200817 yr what is the optimal tuning frequency for the icons? where do they perform best?i know the range is 27-33hz but where in that range would it be best to tune them at.
November 17, 200817 yr Admin I am not sure if you just answered your own question. But what are your goals?
November 17, 200817 yr Tune higher to be louder, lower to be more musical. Rule of thumb right there.
November 17, 200817 yr for a daily driver I find that the 12" sound really good tuned in the 32-33hz range....the output is really good..low end extension is very decent and they still pickup the KICK of the higher drum frequencieswith the tuning down in the 30hz range they like a very low X-Over setting and the upperkick drums are not as punchyI would also stay with in the 1.80 to 2.0cf3 plus displacements
November 17, 200817 yr Author okay thanks guys. i know, in a way, that i did answer my own question but i was wondering where within that range should the box be tuned to for daily use.
November 17, 200817 yr Admin okay thanks guys. i know, in a way, that i did answer my own question but i was wondering where within that range should the box be tuned to for daily use.it's all up to you in the end. I personally like 31-32hz range. Either way, you can't go wrong. Enjoy those subs!
November 18, 200817 yr Author orr...should i just get this loaded enclosure from fisher customs?http://www.fishercustoms.com/store/index.p...p;products_id=9
