This is what i am going to do:
2002 Impala
12" Fi Q dual 2ohm w/o bp option
Kicker ZX750.1
2.5 cf^3 at 32hz ported box tubeafter displacement
Kinetic battery under the hood
Cap
Big 3 upgrade
**NO ALT UPGRADE**
Is all this fine & should anything be changed?
Better amp for a cheaper price?
Any other suggestions or comments?
dump the cap
Dont want my lights to dim & plus it was free. i know it doesnt really do anything for my system power wise
So ill get the dual 1 12" Fi Q and wire the sub and amp how?
Thanks
Thanks
If you know the cap doesn't do anything for you... don't use it.
I doubt you'll get any dimmage with that little power anyway.
It wont hurt anything to have it & my lights might dim. i have seen my inside lights dim before without the system. It also looks kinda cool in my trunk if someone wants to see my system.
When your amp fries from low voltage it will be hurt wont it.
Which kinetik battery should i use, what ga wire should i use on the big 3 upgrade, and does anyone know the stock alternator amperage for a 02 impala 3.4L?
use 1/0 for big 3. you dont have to but you'll get more current, even 4 would make a difference
agreed with using a power master^
