Did a couple of search's and did not find anything close to what I wanted to know. Bassically is the regular anodized aluminum trim plate that sits on top of the map removable without doing anyharm to the amp itself, by removing the 2 SHCS located on either end. Reason why I am asking is I wanted to make a custom plate for mine.
Thanks in advance for any help.
Toolmaker
Yes removable, with out harm that is up to you just make sure you dont slip and scratch it. :P
he is correct
Harm it :madrofl: . Na, it will be just replaced after I make the new one.
thanks for the quick replies.
Why are you making a new one? Do tell!
Basically just to be a little different, add my own signature to the install when I start to do it. There's not much I can't do when it comes to working with raw materials and making an end product. I guess you could call it a little customization.
I would guess that your a "cnc" or tool setter by looking at your name
oh the power of x y z b
I've also thought the same about that center part with the logo on it
Tool and Diemaker actually by trade. I can program,set-up, and run, CNC equipment(lathes,mills,routers,wire edm,etc) on top of my other duties.
thats freaking sweet
