February 14, 200916 yr Author Glad to see you switched amps now for the sub The only way I would take out my X is when I find a woofer that has a bolt in cone and that is better than a X... So as of right now the X is where it's at for me!
February 15, 200916 yr I'm curious how you have that 3000D mounted to the box. I get nervous with my 1500D mounted to my dual RL-i8's enclosure. I can't imagine the vibration that 3000D must experience. Especially with the box bolted to your chassis.I used rubber grommets between the 1500D and the mount points, just for a little bit of absorption. Are you using anything like that? I wouldn't mind finding something even more effective.
February 15, 200916 yr Author I'm curious how you have that 3000D mounted to the box. I get nervous with my 1500D mounted to my dual RL-i8's enclosure. I can't imagine the vibration that 3000D must experience. Especially with the box bolted to your chassis.I used rubber grommets between the 1500D and the mount points, just for a little bit of absorption. Are you using anything like that? I wouldn't mind finding something even more effective. I have never had a problem mounting any amp to a sub box up to 160+ db. I hope I don't start having a problem.... Edited February 15, 200916 yr by Greg McCool
February 15, 200916 yr See you at SBN Greg I wont be competeing but Ill be there supporting every one
February 16, 200916 yr Author See you at SBN Greg I wont be competeing but Ill be there supporting every oneSweet!
February 16, 200916 yr See you at SBN Greg I wont be competeing but Ill be there supporting every oneSweet!yep Ill be riding down with Tommy K and Hank
February 21, 200916 yr Author NSB 90 x21/0 ground for each NSB1/0 lead to altmake custom battery box x22 NSB 90 and some 1/0....empty battery boxbattery box..... but I only need 4in of itThe tray bolted infinished with 1/0 ground, 1/0 power lead to ault and 1/0 run of ground to back NSB 90OEM 1/0?Back NSB 90You would think it was made to come together...I still have to tie in the back battery... I will do it tomorrow..
