I know theirs many of these posts about people asking for a good amp to run there sub but I thought id post my own topic to fit my standards...I have/on the way a 15" Fi SSD. Even though I still haven't received my subwoofer and haven't heard it on my current amp I still don't think my US AMPS XT2000D is going to feed it the power i want. with that being said I want some ideas on a good amp that can put out as much power or a good recommended amount of power to push the SSD. my price range would have to be around 200$ or so...idk just thought id get some ideas if i were to get one soon.
2ohm........so a nice 1ohm amp
how are autotek amps...i know there made by maxxsonics but how do they compare to hifonics and other maxxsonic amplifiers...for example the sm1-1500..would that be good power....too much..?
and about that AQ....do they underrate overrate or is that rms handling right on...how much rms at 1 ohm can i expect at 14volts
  • Admin
AudioQue: AQ 1200D.
No. No need to run that much more power to an 800 watt sub woofer. Spend the same money on a high quality amp of lower power.
check my F/S listing.. I'm sure you'll find something you'd like :D
I wouldn't worry about having a ton of power for that woofer.. try the amp you have first and go from there
I like the AQ option. Give you ALOT of head room, would allow you to keep the settings on the radio down, giving you a cleaner signal. =)
you're probably going to get the same power out of both the sundown 1000d amp and the AQ 1200d if sundown rated that amp at 12.8v and AQ rated their amp at 14.4v.
ssd's do wonders on low power, i have my 12" with bp and flatwound coil and its seeing 30w on my computer stereo and its loud and sounds amazing.
