Posted March 17, 200917 yr Refurbished saz-1500d or new saz-1500d. the new one i can get for 600 and refurbished will be getting for 450.which should i choose?this is coming from db-r.com
March 17, 200917 yr If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long. Edited March 17, 200917 yr by bromo
March 17, 200917 yr I, personally, would buy a refurb from Chris any day of the week. He WILL not screw you over. The amps he sells are as good as new.
March 17, 200917 yr Author If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anyway
March 17, 200917 yr you can come across them used in the classifieds with a good amount of warranty left on them in the $3-$400 range too...
March 17, 200917 yr If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayFor a BL you could pick up a SAE-1200D for $350 new, puts out 1500w
March 17, 200917 yr Author If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayFor a BL you could pick up a SAE-1200D for $350 new, puts out 1500wi rather go saz-1500d. puts out 1800. and just keep my gains down
March 17, 200917 yr If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?
March 17, 200917 yr Author If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level. Edited March 17, 200917 yr by stylezzz8o8
March 17, 200917 yr Author If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?yes i have. have you?
March 17, 200917 yr If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level.... yes it does.That's how you Set your gain. To limit the maximum power output and match your input signal.So I'll assume you know what it is now, just not what it does.
March 17, 200917 yr Author If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level.... yes it does.That's how you Set your gain. To limit the maximum power output and match your input signal.So I'll assume you know what it is now, just not what it does.http://forum.ecoustics.com/bbs/messages/4/499728.htmlread and learn. i know what it does. you dont.
March 17, 200917 yr When you set your gain on your amp you have your gain knob (in cabin) set at max. This allows you to turn the gain down from the cabin, but not to turn it up past it's maximum setting. So if I turn my gain knob down and my sub is making barely ANY sound, you're telling me it's still getting xthousand watts? I think Johnecon knows what he's talking about.
March 17, 200917 yr If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level.... yes it does.That's how you Set your gain. To limit the maximum power output and match your input signal.So I'll assume you know what it is now, just not what it does.http://forum.ecoustics.com/bbs/messages/4/499728.htmlread and learn. i know what it does. you dont.Riddle me this, What happens when your head unit is rated at 4V preout and you set the sensitivity knob to 8V? Edited March 17, 200917 yr by bromo
March 17, 200917 yr If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level.... yes it does.That's how you Set your gain. To limit the maximum power output and match your input signal.So I'll assume you know what it is now, just not what it does.http://forum.ecoustics.com/bbs/messages/4/499728.htmlread and learn. i know what it does. you dont.How about I just call you a retard and everyone laughs
March 17, 200917 yr http://kluvkustoms.com/cgi-bin/online/storepro.php425 pretty sure thats shipped too....
March 17, 200917 yr http://kluvkustoms.com/cgi-bin/online/storepro.php425 pretty sure thats shipped too....It is not valid.Their store should be down but the web host still has it running even though they canceled it - they are no longer a dealer.
March 18, 200917 yr Author believe what you want but im telling you it will produce its maximum outputhttp://www.bcae1.com/gaincon2.htmnuff sedd.
March 18, 200917 yr Author If it is an option and it happens I would wait for a SAZ-2000D for $425 on presale. If you can wait that long.not an option. i have an fi bl. so im looking for 1500. thanks anywayYou don't need to use the full 2kW. Ever heard of a gain knob?gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level.... yes it does.That's how you Set your gain. To limit the maximum power output and match your input signal.So I'll assume you know what it is now, just not what it does.http://forum.ecoustics.com/bbs/messages/4/499728.htmlread and learn. i know what it does. you dont.Riddle me this, What happens when your head unit is rated at 4V preout and you set the sensitivity knob to 8V? then that would make me a dumbass duh
