Posted April 1, 200917 yr i was thinking about getting 2 icon 12s and i was wondering what would be a good amp to run them?i would like to stay cheap but i want a good quality amp.it probably be in the loaded enclosure from fisher customs.so the specs of that box
April 1, 200917 yr Author well since the box from fisher customs loaded is like 700 i would like to stay around 700 Edited April 1, 200917 yr by High_score_1
April 1, 200917 yr wow...700 isn't anywhere to be found in my dictionary under the word "cheap". haha but i guess that's just cause im cheap Edited April 1, 200917 yr by hiloracerboy84
April 2, 200917 yr Admin A quality amplifier that is between 750 and 2200 watts will be plenty to power both. Or what some have done, individual 700-1000 watt amps.
April 2, 200916 yr Author so 2 rockford t1000bds? if i go with the rockfords should i go with dual 1 or dual 2?
April 2, 200916 yr If your going to run the T10001bd amp and you are going to run two of them get dual 2 ohm voice coils..Wire each sub to 1 ohm..
April 2, 200916 yr Author If your going to run the T10001bd amp and you are going to run two of them get dual 2 ohm voice coils..Wire each sub to 1 ohm..thats what i was figuring on doing...that would keep it close to my budjet to.thank you guys for all the help
April 2, 200916 yr Admin so 2 rockford t1000bds? if i go with the rockfords should i go with dual 1 or dual 2?You don't have to do two amplifiers, just saying that some have. If you get these RF's, be easy on the gains and how hard you play the drivers, as I have seen plenty birthing in the 1400watts range. And that is well above the comfort level for thermal limits of the Icon.
April 3, 200916 yr so 2 rockford t1000bds? if i go with the rockfords should i go with dual 1 or dual 2?A R/F T1500-1bd on 1 ohm...Two dual 1 ohm coil subs FTW...
April 3, 200916 yr I have punched over double the rated RMS into the Icons and pushed themas far as they are capable of goingI was un able to do any coil damage what so ever with a clean signalbut like any other sub it will come apart if over exerted with to muchpower....the suspension can only take so much before it lets goI would recommend staying close to the RMS rating with a good enclosureand a properly set amp...you will get good life out of them and not void warranty
April 3, 200916 yr If you want cheap then you can go with a refurb Sundown 1500. Thats what I did and it comes with a 1 year warranty. They are 350.
April 4, 200916 yr Author I'd recommend a single amp and not using 2.does it work better? more power? or something like that.i've always only have one sub at a time so i've always ran just one amp lol.
