Hi i will be buying 2 fully loaded bl 15's and i have a 2001 blazer extreme i plan on making the box around 8 cubic feet and about 32 hertz and a 200 amp alternator with 0 guage wire and i was wondering which amp to go with ehtier 2 of the Hifonics BXi 2008D or 1 Pioneer Premier PRS-D2000SPL so if some one could help me out or tell me which amp would go good.
my price range for amps is about 400 to about 800 max so i would greatly apperiate it if some one could help me out thanks
For the money you will spend on either of those amps you can get a MUCH better one.
As Bobaflob said, get the Sundown and go bang.
If that Pioneer Premier is similar in build quality to their smaller premier amps, it's very solid. Pioneer really did a good job engineering those, IMO, far better than their other amp lines and Hifonics. The smaller Premier amps (two channel) also do nearly twice rated power.
so would i only need one SAZ-2000d bobaflob ? and do you have any estimate on what db's ill be hitting ?
and thanks every for the help
One 2000d would be fine, and no, we don't have any estimates for you.
Is this for daily driving or competing?
i am using this for a daily driver but i also have in mind 3 - fi bl's fully loaded and a SAZ-3000D amp
would that sound good ?
That would def work. But if you wanted to do that then i would just say get two btls but thats up to you
Depends on your build and install
