Posted April 23, 200917 yr I was looking at the options for the new 12" BTL im getting and i cant seem to find anywhere on the site that explains what the "HiXmCoil" and "I Heat Ring" dosorry if i overlooked somethingthanks for the explanations in advance.Tyler
April 23, 200917 yr HiXmCoil: This coil is simply much longer than the normal dual 1ohm or dual 2ohm flatwire coils and allows for more xmax. If you are using this in a daily scenario we suggest that you choose this option, especially in the 15 and 18 inch models.Inner Heat Sink: Its a machined aluminum ring in the gap that lowers the voicecoils inductance (allowing it to play up higher and have a little better overall transient response). It also reduces the volume inside the magnet gap of the motor increasing air speed with the cooling as well as allowing the coil to kick off heat to a more receptive thermal mass rather than magnets.
April 23, 200917 yr Author *hits self* I have NO i dea how i didnt see the definitions when i looked under tech. lol. thanks for the responses though.
April 23, 200917 yr I honestly think it makes a difference as well..... I've never never heard something that sounds as good as a fully loaded 18" BTL.
April 24, 200917 yr really? 28mm is what it says on the website. i thought that it would go higher because its a add on option.
April 24, 200917 yr really? 28mm is what it says on the website. i thought that it would go higher because its a add on option.That's With The Option. Without It It's Around 16mm-18mm If I Remember Correctly.
