Posted June 9, 200917 yr Not at the same time!I have two boxes built for my single 12BL. (D2, loaded, daily)One is 2.5cuft @ 32. Slot port. HomemadeThe other is 2.0cuft @ 32. Kerfed port. PTSThey are both designed around the 12BL t/a parameters.Two questions.Is the BTL a substantial upgrade from the BL?Could I use the 12BTL in the same box which was designed for the 12BL? Edited June 9, 200917 yr by b34tBoX
June 11, 200917 yr Author So using the BTL used in an enclosure designed for the BL is OK, or should I build another?
June 11, 200917 yr Look at your box and description and read the thread John pointed you to. It should not only answer your question but make you feel like that part of your question was easy to answer.As for the "upgrade" that all depends on your goals. Personally it would do nothing for me, but for you it will probably be much different.
June 11, 200917 yr There's nothing wrong with using the same box.In this case there isn't. Generally you wouldn't want to though.
