Posted July 19, 200916 yr I'm about to order a dual amp kit from KnuKoncepts:http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK20What are the correct fuses I would need for the Inline Fuse and the Fuse Block for wiring up a 1500D and a 50.4.Thanks
July 19, 200916 yr 1 300a fuses for the 0g wire in the single fuse holder, 2x 150a mini fuses for the 4g wire in the dual fuse holder.Fuse to the wire.
July 19, 200916 yr Author 1 300a fuses for the 0g wire in the single fuse holder, 2x 150a mini fuses for the 4g wire in the dual fuse holder.Fuse to the wire.Tank you veddy much
July 19, 200916 yr yeah a 250-300 ANL FUSE, 1-150A midifuse for 1500D and 1-60A or 80A midifuse for 50.4
July 19, 200916 yr Author yeah a 250-300 ANL FUSE, 1-150A midifuse for 1500D and 1-60A or 80A midifuse for 50.4Thanks.
