Posted July 26, 200916 yr Would 1 10" bl with cooling and flatwind coil in a 1.4 cuft box tuned to 32hz be louder than 2 10" ssds in a 1.8 cuft Tuned to 33hz? Also what would be the ideal port area for the ssds if I put them in a box with two ports? Thanks
July 26, 200916 yr Would 1 10" bl with cooling and flatwind coil in a 1.4 cuft box tuned to 32hz be louder than 2 10" ssds in a 1.8 cuft Tuned to 33hz? Also what would be the ideal port area for the ssds if I put them in a box with two ports? Thanks2-10" ssd's in my opinion, you would need anywhere between 21.6in^2 - 28.8in^2(divide that in two if you want to make two ports).
July 27, 200916 yr Author awesome! but could i go any smaller than 1.8cuft? im really pressed for space since these are going under my rear f150 seats
July 27, 200916 yr if i were you i would just go with one of those MTX thunder forum or whatever their called they make them for 2 10s unless you want to get into some fab work. Plus the look like something that came with the truck...they look clean and stealthy. as far as space I wouldn't go less than 1.6 MINIMUM
July 27, 200916 yr Author well i already put in my seat lift and have my amp (sundown audio sae1200d) but im still looking for the right sub/ subs. I want either 2 10s with 600w rms handling and 6" mounting depth and require like .7 cuft ported or 1 10 or 12 with 1500w rms and 6.25" mounting depth and 1.4 cuft ported
July 27, 200916 yr well i already put in my seat lift and have my amp (sundown audio sae1200d) but im still looking for the right sub/ subs. I want either 2 10s with 600w rms handling and 6" mounting depth and require like .7 cuft ported or 1 10 or 12 with 1500w rms and 6.25" mounting depth and 1.4 cuft portedgood with what can fit because crampped subs in a small box will not sound to good or give you the best output. just my .02
July 27, 200916 yr Author well i already put in my seat lift and have my amp (sundown audio sae1200d) but im still looking for the right sub/ subs. I want either 2 10s with 600w rms handling and 6" mounting depth and require like .7 cuft ported or 1 10 or 12 with 1500w rms and 6.25" mounting depth and 1.4 cuft portedgood with what can fit because crampped subs in a small box will not sound to good or give you the best output. just my .02alright yeah i think im gonna go with the 10" Bl with cooling and flatwind
July 27, 200916 yr Don't forget you have to subtract port volume from the total volume of the box too.
July 27, 200916 yr Don't forget you have to subtract port volume from the total volume of the box too.and the sub woofers displacement also
July 27, 200916 yr Don't forget you have to subtract port volume from the total volume of the box too.and the sub woofers displacement alsolol and bracing.
July 27, 200916 yr Don't forget you have to subtract port volume from the total volume of the box too.and the sub woofers displacement alsolol and bracing.x2
July 28, 200916 yr Author yeah i factored all that in except for bracing... i didnt think i needed it since the box is like 2.2 cuft
July 28, 200916 yr yeah we were just joking for your situation (but for some people who dont know that those values must be thrown into the equation when building a ported enclsosure).
