Posted September 1, 200916 yr First off Im gonna get either a BTL or Kicker, cant make up my mind. Either a Kicker SoloX 15(2) or Fi BTL 15(2), the kicker can handle 2500RMS @DVC 2 ohms and the BTL can handle 2000RMS @DVC 2 ohms.. So would the BTL 15 be able to handle 2500RMS or higher with the P Chamfer, Cooling, HiXmCoil, Daily, I Heat Ring, and not universal options? Also Im gonna try to put these in a lincoln LS, and I cant determine if I want BTL15s or BTL12s, which would you guys suggest?p.s. the amp I will probably be using is a SPL FX1-5500D with 2500RMS @ 2ohm, 3200RMS @ 1 ohm, is that a good idea or anyone got any other suggestions?Thanks a lot, an obvious newbie
September 1, 200916 yr Author First off Im gonna get either a BTL or Kicker, cant make up my mind. Either a Kicker SoloX 15(2) or Fi BTL 15(2), the kicker can handle 2500RMS @DVC 2 ohms and the BTL can handle 2000RMS @DVC 2 ohms.. So would the BTL 15 be able to handle 2500RMS or higher with the P Chamfer, Cooling, HiXmCoil, Daily, I Heat Ring, and not universal options? Also Im gonna try to put these in a lincoln LS, and I cant determine if I want BTL15s or BTL12s, which would you guys suggest?p.s. the amp I will probably be using is a SPL FX1-5500D with 2500RMS @ 2ohm, 3200RMS @ 1 ohm, is that a good idea or anyone got any other suggestions?Thanks a lot, an obvious newbieAlso since I have the daily option I will be bumpin 24/7 if possible so can it handle 2500rms safely under those conditions?
September 1, 200916 yr *topics mergedPlease read the noob posting guideilnes (in my sig) and don't ever double post a thread again.
September 1, 200916 yr Author *topics mergedPlease read the noob posting guideilnes (in my sig) and don't ever double post a thread again. so you complain about me 'double posting' but wont help at all, nice...
September 2, 200916 yr Admin *topics mergedPlease read the noob posting guideilnes (in my sig) and don't ever double post a thread again. so you complain about me 'double posting' but wont help at all, nice...He is a moderator, he is doing is job, and he is not complaining.Anyway, to the topic at hand, if this is for a daily installation, I personally don't feel the SoloX should be in the conversation. The BTL is quite a driver, read up on the options and figure out which ones are best for you and your install.
September 2, 200916 yr the BTL would be the better choice for a daily driver...the SoloX is more a sub for burps. The BTL, from what I've heard and seen are amazing drivers and would be a lot more musical for daily use then the SoloX
September 2, 200916 yr *topics mergedPlease read the noob posting guideilnes (in my sig) and don't ever double post a thread again. so you complain about me 'double posting' but wont help at all, nice...And if you read the noob guidelines I told you to you'd know why, having an attitude isn't going to help you get the answers you want nor will make uninformative threads.
September 2, 200916 yr First off Im gonna get either a BTL or Kicker, cant make up my mind. Either a Kicker SoloX 15(2) or Fi BTL 15(2), the kicker can handle 2500RMS @DVC 2 ohms and the BTL can handle 2000RMS @DVC 2 ohms.. So would the BTL 15 be able to handle 2500RMS or higher with the P Chamfer, Cooling, HiXmCoil, Daily, I Heat Ring, and not universal options? Also Im gonna try to put these in a lincoln LS, and I cant determine if I want BTL15s or BTL12s, which would you guys suggest?p.s. the amp I will probably be using is a SPL FX1-5500D with 2500RMS @ 2ohm, 3200RMS @ 1 ohm, is that a good idea or anyone got any other suggestions?Thanks a lot, an obvious newbieFor starters answer some general questions, whats the electrical upgrades you plan on doing, how much room do you have in your trunk and what other equipment will be in this install?I dont think two 15"s would fit in a Lincoln LS but I could be wrong, 2-12"s may suit your better. Thats not a good choice of amps, grab you a Sundown SAZ-3500 or SAZ-4500D or Incriminator Audio IA40.1.
September 3, 200916 yr Author First off Im gonna get either a BTL or Kicker, cant make up my mind. Either a Kicker SoloX 15(2) or Fi BTL 15(2), the kicker can handle 2500RMS @DVC 2 ohms and the BTL can handle 2000RMS @DVC 2 ohms.. So would the BTL 15 be able to handle 2500RMS or higher with the P Chamfer, Cooling, HiXmCoil, Daily, I Heat Ring, and not universal options? Also Im gonna try to put these in a lincoln LS, and I cant determine if I want BTL15s or BTL12s, which would you guys suggest?p.s. the amp I will probably be using is a SPL FX1-5500D with 2500RMS @ 2ohm, 3200RMS @ 1 ohm, is that a good idea or anyone got any other suggestions?Thanks a lot, an obvious newbieFor starters answer some general questions, whats the electrical upgrades you plan on doing, how much room do you have in your trunk and what other equipment will be in this install?I dont think two 15"s would fit in a Lincoln LS but I could be wrong, 2-12"s may suit your better. Thats not a good choice of amps, grab you a Sundown SAZ-3500 or SAZ-4500D or Incriminator Audio IA40.1.Im not sure exactly the space of the trunk, Im in a different country right now, but I do agree I think 12s will be a better idea.. and as far as electrical upgrades I think Im just gonna get a high output aftermarket alternator, unless you guys have other suggestions. Id be installing just 2 batteries, two amps, and two subs, so nothing to special. And why not choose that amp? What websites can I find those amps on?
September 3, 200916 yr Author *topics mergedPlease read the noob posting guideilnes (in my sig) and don't ever double post a thread again. so you complain about me 'double posting' but wont help at all, nice...And if you read the noob guidelines I told you to you'd know why, having an attitude isn't going to help you get the answers you want nor will make uninformative threads.PS I apologize for 'giving you attitude'.. I didnt view it as that but others have different perspectives.. I just dont really give people who stop by and enjoy 'yelling' at me, but you are doing your job I guess. Also it wasnt an uninformative thread, its trying to get some answers. I cant get answers from anywhere else.
September 7, 200916 yr Without a doubt u are better off with the FI Line of drivers ,,,i would never consider the Kicker line myself ,only because i have seen them in action ,,, Overall FI all the way
