September 11, 200916 yr which one of these would be the correct way to measure the port length? entrance of one and exit of the other maybe? also, does a flare just help with port noise? and does that brace inside the port do anything to the tuning? raise it a bit maybe?
September 11, 200916 yr Author I add the proper displacement to the enclosure to aquier for the bracingso it has no effect on tuning..I do have a formula for the port length..it changes with each port flare radius
September 12, 200916 yr I guess its time to hit up google and do some searching I guess. wanna make my next box fancy!on the L7 box you posted, is that black section automotive paint?
September 12, 200916 yr Author the Kicker box has a black coating..non automotivehope that helps...LOL
September 12, 200916 yr well, whatever you use your boxes look awesome, Ill probably use some rhino lining on mine or something...
September 14, 200916 yr whats the pricing on a box like this? and if i design it myself and just have you build it? do you ship?
September 15, 200916 yr Just wanted to let people know that I am currently using a home built enclosure. 2.5cuft @ 32Hz for my 12" Fi BL.Next year, I will be upgrading to a 12" BTL and am very curious to how the boxes will compare..I hope to receive the enclosure before I put my car away for winter so I can compare them while I still have the BL.
September 16, 200916 yr This one is marvelous !It is not box building anymore, it's just ART !!!!!!!!!
September 20, 200916 yr Anyways, I would assume that there would be no problems using a BTL sub in a box designed for a BL, right?Could anyone please confirm? Edited September 20, 200916 yr by b34tBoX
September 22, 200916 yr Anyways, I would assume that there would be no problems using a BTL sub in a box designed for a BL, right?Could anyone please confirm?no problems in one of these boxes, the only thing i would be concerned about is port noise, but in one of these there shouldnt be any... Edited September 22, 200916 yr by Anton Miller
September 22, 200916 yr Author the tuning would be a little off with the BTL but it will work the same.....
September 22, 200916 yr I bet the UPS driver likes coming to your house to pick up all these heavy bastards.
April 14, 201015 yr I just sent ya an email about a box for this exact sub. I love this box i might want a flared port just like this one instead of a normal slot port. AMAZING work man. Deff gonna get it from u.
