September 14, 200917 yr Admin The all new Kronos is a 2 channel amplifier that can be run at 8 ohms or 4 ohms mono, with ratted out put at 500 and 1000 watts respectively.
September 15, 200917 yr A lot of the amplifers that zed made dont go below 2 ohm. He doest not believe in the low impedances cause it is harsh on the amps. How much power are you looking for and i can make a list for ya??
September 15, 200917 yr The all new Kronos is a 2 channel amplifier that can be run at 8 ohms or 4 ohms mono, with ratted out put at 500 and 1000 watts respectively.Sorry to jump in on this thread, but how much sound quality do you feel you would lose running the Kronos in a 2 ohm Load? I have a pair of dual 4 ohm subs that would either give me 2 x 500 watts @ 2 ohms or 125 watts x 2 @ 8 ohms. It would be closer to 150 watts though per side at clip according to Mr. Mantz .who says the Kronos will do about 300 watts per channel / 4 ohm at clip or 150 watts per channel @8 ohm at clip. Not sure about how much loss in sound quality would be on the subwoofers, but it sure would be nice to use the smaller amp. Edited September 15, 200917 yr by JWPOORE
September 15, 200917 yr Admin The all new Kronos is a 2 channel amplifier that can be run at 8 ohms or 4 ohms mono, with ratted out put at 500 and 1000 watts respectively.Sorry to jump in on this thread, but how much sound quality do you feel you would lose running the Kronos in a 2 ohm Load? I have a pair of dual 4 ohm subs that would either give me 2 x 500 watts @ 2 ohms or 125 watts x 2 @ 8 ohms. It would be closer to 150 watts though per side at clip according to Mr. Mantz .who says the Kronos will do about 300 watts per channel / 4 ohm at clip or 150 watts per channel @8 ohm at clip. Not sure about how much loss in sound quality would be on the subwoofers, but it sure would be nice to use the smaller amp. If I understand you correctly, why not run the Kronos at 4 ohm mono?4 4 + 4 4 2 + 2 4 ohm mono.
September 15, 200917 yr The all new Kronos is a 2 channel amplifier that can be run at 8 ohms or 4 ohms mono, with ratted out put at 500 and 1000 watts respectively.Sorry to jump in on this thread, but how much sound quality do you feel you would lose running the Kronos in a 2 ohm Load? I have a pair of dual 4 ohm subs that would either give me 2 x 500 watts @ 2 ohms or 125 watts x 2 @ 8 ohms. It would be closer to 150 watts though per side at clip according to Mr. Mantz .who says the Kronos will do about 300 watts per channel / 4 ohm at clip or 150 watts per channel @8 ohm at clip. Not sure about how much loss in sound quality would be on the subwoofers, but it sure would be nice to use the smaller amp. If I understand you correctly, why not run the Kronos at 4 ohm mono?4 4 + 4 4 2 + 2 4 ohm mono.I wasn't aware that I could run it that way, If so, they that would for sure be the method I would chose. Mr. Mantz did not give me that option when I emailed him. He only gave me the 2 x 2 ohm route or the 2 x 8 ohm route. If there is someway to confirm that the 4 ohm mono is an option, then I have finally found my ideal amp for size, power and great quality.
September 16, 200917 yr Author Well i have 2 15" level 4 xl's and my current amps r to small what do you think would be the best choice
September 16, 200917 yr Well i have 2 15" level 4 xl's and my current amps r to small what do you think would be the best choiceHere are the ones I could find... Hifonics colossus VIII -- 1800 watts @ 4ohmsHifonics zeus VI - VIII -- 900 @ 4ohmslanzar 1000.1d -- 1000 @ 1ohmrodek 2300i -- 900 @ 4ohmsUs Acoustics usa2300 -- 900 @ 4ohms
September 22, 200917 yr Well i have 2 15" level 4 xl's and my current amps r to small what do you think would be the best choiceHere are the ones I could find... Hifonics colossus VIII -- 1800 watts @ 4ohmsHifonics zeus VI - VIII -- 900 @ 4ohmslanzar 1000.1d -- 1000 @ 1ohmrodek 2300i -- 900 @ 4ohmsUs Acoustics usa2300 -- 900 @ 4ohmsYou forgot the HiFonics Son of Colossus Generation X which the manual shows 1100 watts @ 2 ohms.
