So i picked up my 18 inch btl with hiXM coil and cooling options(DAILY). Now for the amp. Normally i would say that i don't have the money for the SAZ-3000D, but i found it online refurbished for the same price that i can pick up the Rockford Fosgate t2001BD from sonicelectronix. I read a post from a guy who got the refurbished SAZ-3000D and he claimed that it was functionally perfect so i wouldn't mind purchasing it. both are about $560. I plan on doing all the elcetrical upgrades necessary for either of these amps (big 3, Kinetic hc2000, high output amp, all that good stuff) now my only concern is that my sub is the dual 2 ohm and i will be running it down to 1 ohm like most. But the sub is rated at 2000wrms and the SAZ-3000D puts out 3000 watts at 1 ohm and i reallllllly don't wanna blow this BTL. The Rockford Fosgate runs at 2000 watts at one ohm. I've heard really great things about both of these amps. Anyone else got anymore advice?
thanks
thanks
Running my BTL off of a sundown audio 3000D daily giving it all it's got. No problems :)
Be smart with it and the BTL loves it.
I would go with the Sundown because thats were i got my 3000d....DB-r is excellent with customer service... :wacky:
sundown all the way there amps are just built like beasts. i love my sundown amps!
and you dont have to give it all the power that the saz is capable of producing, set the gain so your making less power.
x2, get a DMM(digital multi-meter and set the gains to what rms you want to throw at the sub). Sundown SAZ-3000d FTW!
Both great companies, set your gains right for the Sundown and it'll treat you, plus it does rated power + more
I personally love Sundown just cause i own the 3000d new heat sink model. built like a beast buy it cheap refurbished b-stock from www.db-r.com got mine for 571 with shipping
  • 2 weeks later...
that's probably what i will do! thanks
