  • Replies 350
  • Views 48.5k
  • liljestrand
    liljestrand
    Amp rack in the process. Using bolts and tnuts. Fitted in. Will have more wire once I get my 4 pairs of duals from project db. Upgraded the mids. Hertz ml165 going to build some pods in the do
  • liljestrand
    liljestrand
    Got a deal on a second bc5500. Gonna strap them at .5 on the sp4s
  • A smidgen of an update: All new projectdb metal. Battery terminals, triple inputs, and 12x12 distro's. The distro's with the + and - ran. Thats 18 of each. this is with the 6 + and 6 - 2/0 weldin
Comparing outside physical characteristics of a motor is a terrible way to compare woofers. They are two completely different woofers who share the same size ferite slugs.
looking good, I think th SP4 motor should have been bigger considering the coil size
agreed... its weird how the SP4 and the Zcon look like they have the same motor...
Ironic?
All SSA motors look nearly identical to Fi models.
perhaps the same company lol
the top plate and bottom plate are diff of course to fit the coil.
yes the wofferes are very different, motors not so much lol.
I think it would be interesting to compare a SP4 to a ti styled sub with a 4hp :)
this is the rough sketchup...and i mean rough....of the new box....should be just over 6 cubes after displacement
looking good sir!
Get it going man! :-)
No more Zcons ? You're running Fi sp4's now. Why did you change ?! :)
Nice installs
No more Zcons ? You're running Fi sp4's now. Why did you change ?! smile.png
Nice installs
So he could run a sealed box instead of a ported box
Nice installs
I read the same a while back but not it looks like he's building a ported box. Am I wrong?
:TMNT:
I did state the change was to go sealed and get my backseat back.
I met up with some team nwspl guys and they felt we could build a ported box in the cargo area.
So the box will be ported but it will be small for the zcons optimally.
It will be roughly 6 cubes after displacements.
We will do some straight up test because not only I but some team members are interested in the results.
And Sen posted a pic of one of my problems I found today. The crescendo pa mids are a Tad bigger than the ia comps I had
I am tuned in!
I heard the Crescendo mids are not as impressive as a lot of people hoped they would be, they are getting a couple things changed on them with the new batch coming out. Navid is always improving things
Most of the problems are either weak terminal mounts. Or a scratchy sound. The scratchy sound means something got in the coil gap. If you unscrew the middle bullet thing and spray air in there it should clear it out.
But hey its a beefy little speaker for only 25 bucks. Hopefully get to hear it this week. Will be matching these with their ft1 supertweets
On the crescendo 1100.4
Cant wait to see the box phil
And even better the results :)
Well box will be built tomorrow. Can't wait!
Heres some pics to tide you over.
how everything looks below the cargo floor. It's a bit messy but I had to do what i could to get this ready for the box build tomorrow.
And yes i know the inputs are above the other amp. I have a rubber mat underneath them atm till something better can be thought of.
Cargo floor back in waiting on the box build.
Team NWSPL shirts!
Nice!!! I don't gots a team.. But I play for all... lol
Project DB 1/0 to 4g adapters on the 1100.4
Starting the box.
Back wall
And thats where we are at. Was a good day of good company and much bs'ing.
Box will be sanded inside and out, and painted black. With adjustable ports...32hz for daily and 50hz for burping. roughly 10ish cubes after displacements.
Looking good Phil, I'm very interested in what you think of this setup. Great progress so far!
Great!!! Someone said you were going sealed???LOL... what happened???
I didn't think it was gonna be possible to do ported in the back. The Team NWSpl guys told me otherwise lol.
Mhmm! I'm excited for you!!
box looks good so far!
