Posted October 26, 200917 yr So I picked up a pair of Hertz Hsk165's and need some help with choosing an amp.Amp will be ran off of a kenwood 8120.I have about 400 to spend... but I wouldn't mind spending less.Im thinking about the following:sundown sax-125.2$240(even a 50.4 bridged thoughts???)audio systems twister 300$300jl 300/2$350steg K2|02$450arc ks300.2$399what are your thoughts on the ones posted? any recommendations?
October 27, 200917 yr i would just go with the sundown. all of those are good amps from what i have seen and heard a couple of them. cant go wrong with sundown but just listen to what everyone has to say about them and then pick
October 27, 200917 yr Author So I picked up a pair of Hertz Hsk165's and need some help with choosing an amp.Amp will be ran off of a kenwood 8120.I have about 400 to spend... but I wouldn't mind spending less.Im thinking about the following:sundown sax-125.2$240http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAX%252d125.2.html(even a 50.4 bridged thoughts???)http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAX%252d50.4.htmlaudio systems twister 300$300http://www.audiosystem-america.com/f2300.htmljl 300/2$350steg K2|02$450http://mobile.jlaudio.com/products_amps.php?amp_id=436arc ks300.2$399http://www.arcaudio.com/productdescription_pages/amplifiers/ks-series/ks3002.aspwhat are your thoughts on the ones posted? any recommendations?here are the links.
October 28, 200917 yr the sundown 125.2 over the 50.4, two-channel amps especially compared to bridging a 4-channel will have better channel separation and slightly better signal to noise. so basically the 125.2 will be cleaner. the JL is a good amp, but In my experience I have yet to see one of their amps live up to what they say they can do. I have also seen several blow capacitors for no apparent reason (grant you I didn't install those). the other amp I would recommend along with the 125.2 would be the arc audio amp. arc audio makes an incredible product. I think on those speakers you won't hear the 160 dollar difference between the two amps. just an FYI though, I run Hybrid Audio Legatia mids/highs off of sundown 100.4d's and the sound is quite astounding.
October 29, 200917 yr Author the sundown 125.2 over the 50.4, two-channel amps especially compared to bridging a 4-channel will have better channel separation and slightly better signal to noise. so basically the 125.2 will be cleaner. the JL is a good amp, but In my experience I have yet to see one of their amps live up to what they say they can do. I have also seen several blow capacitors for no apparent reason (grant you I didn't install those). the other amp I would recommend along with the 125.2 would be the arc audio amp. arc audio makes an incredible product. I think on those speakers you won't hear the 160 dollar difference between the two amps. just an FYI though, I run Hybrid Audio Legatia mids/highs off of sundown 100.4d's and the sound is quite astounding.thanks for your response!just thought id add that i can get an arc ks300.4 for $325 shipped thats only a few months old.and its only 90wrms per channel but 350x2 @ 4ohms bridged.are the sundown sax line under rated like their sae/saz line?
October 29, 200917 yr the sundown 125.2 over the 50.4, two-channel amps especially compared to bridging a 4-channel will have better channel separation and slightly better signal to noise. so basically the 125.2 will be cleaner. the JL is a good amp, but In my experience I have yet to see one of their amps live up to what they say they can do. I have also seen several blow capacitors for no apparent reason (grant you I didn't install those). the other amp I would recommend along with the 125.2 would be the arc audio amp. arc audio makes an incredible product. I think on those speakers you won't hear the 160 dollar difference between the two amps. just an FYI though, I run Hybrid Audio Legatia mids/highs off of sundown 100.4d's and the sound is quite astounding.thanks for your response!just thought id add that i can get an arc ks300.4 for $325 shipped thats only a few months old.and its only 90wrms per channel but 350x2 @ 4ohms bridged.are the sundown sax line under rated like their sae/saz line?They are, and think a 100.4 would make you very happy. Nice truck too
October 29, 200917 yr Author the sundown 125.2 over the 50.4, two-channel amps especially compared to bridging a 4-channel will have better channel separation and slightly better signal to noise. so basically the 125.2 will be cleaner. the JL is a good amp, but In my experience I have yet to see one of their amps live up to what they say they can do. I have also seen several blow capacitors for no apparent reason (grant you I didn't install those). the other amp I would recommend along with the 125.2 would be the arc audio amp. arc audio makes an incredible product. I think on those speakers you won't hear the 160 dollar difference between the two amps. just an FYI though, I run Hybrid Audio Legatia mids/highs off of sundown 100.4d's and the sound is quite astounding.thanks for your response!just thought id add that i can get an arc ks300.4 for $325 shipped thats only a few months old.and its only 90wrms per channel but 350x2 @ 4ohms bridged.are the sundown sax line under rated like their sae/saz line?They are, and think a 100.4 would make you very happy. Nice truck toowould a 100.4 be beneficial seeing as the comps are 125rms rating and im only running 1 set of comps passively?and thanks, but the truck is a photoshop... it just lowered on stock 16s.
October 29, 200917 yr the sundown 125.2 over the 50.4, two-channel amps especially compared to bridging a 4-channel will have better channel separation and slightly better signal to noise. so basically the 125.2 will be cleaner. the JL is a good amp, but In my experience I have yet to see one of their amps live up to what they say they can do. I have also seen several blow capacitors for no apparent reason (grant you I didn't install those). the other amp I would recommend along with the 125.2 would be the arc audio amp. arc audio makes an incredible product. I think on those speakers you won't hear the 160 dollar difference between the two amps. just an FYI though, I run Hybrid Audio Legatia mids/highs off of sundown 100.4d's and the sound is quite astounding.thanks for your response!just thought id add that i can get an arc ks300.4 for $325 shipped thats only a few months old.and its only 90wrms per channel but 350x2 @ 4ohms bridged.are the sundown sax line under rated like their sae/saz line?They are, and think a 100.4 would make you very happy. Nice truck toowould a 100.4 be beneficial seeing as the comps are 125rms rating and im only running 1 set of comps passively?and thanks, but the truck is a photoshop... it just lowered on stock 16s.You could run them actively. And if not, if you get more speakers later, like rear speakers or something, you could use the other channels.
October 29, 200917 yr Author the sundown 125.2 over the 50.4, two-channel amps especially compared to bridging a 4-channel will have better channel separation and slightly better signal to noise. so basically the 125.2 will be cleaner. the JL is a good amp, but In my experience I have yet to see one of their amps live up to what they say they can do. I have also seen several blow capacitors for no apparent reason (grant you I didn't install those). the other amp I would recommend along with the 125.2 would be the arc audio amp. arc audio makes an incredible product. I think on those speakers you won't hear the 160 dollar difference between the two amps. just an FYI though, I run Hybrid Audio Legatia mids/highs off of sundown 100.4d's and the sound is quite astounding.thanks for your response!just thought id add that i can get an arc ks300.4 for $325 shipped thats only a few months old.and its only 90wrms per channel but 350x2 @ 4ohms bridged.are the sundown sax line under rated like their sae/saz line?They are, and think a 100.4 would make you very happy. Nice truck toowould a 100.4 be beneficial seeing as the comps are 125rms rating and im only running 1 set of comps passively?and thanks, but the truck is a photoshop... it just lowered on stock 16s.You could run them actively. And if not, if you get more speakers later, like rear speakers or something, you could use the other channels.i dont even want to mess with going active. lolthis will be my first install so i just want to get the basics down.
October 29, 200917 yr I vote 125.2. I have one and its awesome. Right now I have it running a Z15. lol
October 29, 200917 yr Admin I have not had any experience with the Steg amps, but the Sundown and JL's are excellent options.
November 1, 200916 yr Author would i be able to hear the $210 difference though?and i also dont have have a windows laptop to use that feature.i missed out on a sax125.2 for $120 by 8min too!
November 1, 200916 yr MB Quart DSC4125 $180 sonicelctronixummmm NO, OP please don't even look at this amp, it is OK, but wal-mart compared to arc and sundown, steg...now it seems you need to think about the future....the arc or the 100.4d would be plenty for those speakers even unbridged. and either could run them actively which actually can be safer for your tweeter since passives are generally only 12db/slope, and both those amps have 24 db/slope which will help keep tweeters from playing too low. most ppl blow tweets on passive setups, not the woofer. if you don't plan on running any more mids/highs in future then go with the 125.2 no questions asked. if you plan on running others in the future then get the arc or the sundown, both are amazing amplifiers, arc is and has been quite proven in SQ competition. and any arc or sundown amp will push more than rated power even after normal voltage drop.
November 2, 200916 yr Author MB Quart DSC4125 $180 sonicelctronixummmm NO, OP please don't even look at this amp, it is OK, but wal-mart compared to arc and sundown, steg...now it seems you need to think about the future....the arc or the 100.4d would be plenty for those speakers even unbridged. and either could run them actively which actually can be safer for your tweeter since passives are generally only 12db/slope, and both those amps have 24 db/slope which will help keep tweeters from playing too low. most ppl blow tweets on passive setups, not the woofer. if you don't plan on running any more mids/highs in future then go with the 125.2 no questions asked. if you plan on running others in the future then get the arc or the sundown, both are amazing amplifiers, arc is and has been quite proven in SQ competition. and any arc or sundown amp will push more than rated power even after normal voltage drop.as soon as i saw "sonicelctronix" i knew it was a no.i think its between the sax 125.2 or 100.4... only reason im considering a 100.4 is to possibly grow down the road.and im also most likely going with a 1500d or 2000d for a sub amp too match.
November 2, 200916 yr MB Quart DSC4125 $180 sonicelctronixummmm NO, OP please don't even look at this amp, it is OK, but wal-mart compared to arc and sundown, steg...now it seems you need to think about the future....the arc or the 100.4d would be plenty for those speakers even unbridged. and either could run them actively which actually can be safer for your tweeter since passives are generally only 12db/slope, and both those amps have 24 db/slope which will help keep tweeters from playing too low. most ppl blow tweets on passive setups, not the woofer. if you don't plan on running any more mids/highs in future then go with the 125.2 no questions asked. if you plan on running others in the future then get the arc or the sundown, both are amazing amplifiers, arc is and has been quite proven in SQ competition. and any arc or sundown amp will push more than rated power even after normal voltage drop.as soon as i saw "sonicelctronix" i knew it was a no.i think its between the sax 125.2 or 100.4... only reason im considering a 100.4 is to possibly grow down the road.and im also most likely going with a 1500d or 2000d for a sub amp too match.Ive got one for sale, a local guy offered 275 for it but can't pay til next month. He turned down my offer to hold it for him so if you're interested, PM me.
November 2, 200916 yr would i be able to hear the $210 difference though?No.x2, but your pocket will fill the difference thats all.
November 2, 200916 yr The SAX-100.4 is a very flexible amplifier. Great crossover options, variable subsonic filter and the rated 100 watts per channel is a conservative rating. You could run this amp on front passive comps and run a 4 ohm mono sub bridged. There are a lot options available on the Sundown.
November 2, 200916 yr If you're on a budget(like me!!!) The Sundown 50.4 is a great deal. It was $200 shipped to all 48.I run it bridged to my comp set (focal 165KP) ; I think the speakers really came alive with this amp. So much power to play with : 2 x 160 clean watts at 4 Ohms.I like it a lot.The 125.2 is maybe a better choice? I don't know.I needed my 2 rca's'to run my speakers on the 50.4You just need one set of rca on the 125.2. It's up to you.
November 11, 200916 yr Author i was pretty set on sundown, but now i can pick up a Arc ks 300.4 (90x4) and a ks 1000.1 (1000x1) used for around $580.what would you guys do?how underrated are those amps?
November 11, 200916 yr MB Quart DSC4125 $180 sonicelctronixummmm NO, OP please don't even look at this amp, it is OK, but wal-mart compared to arc and sundown, steg...now it seems you need to think about the future....the arc or the 100.4d would be plenty for those speakers even unbridged. and either could run them actively which actually can be safer for your tweeter since passives are generally only 12db/slope, and both those amps have 24 db/slope which will help keep tweeters from playing too low. most ppl blow tweets on passive setups, not the woofer. if you don't plan on running any more mids/highs in future then go with the 125.2 no questions asked. if you plan on running others in the future then get the arc or the sundown, both are amazing amplifiers, arc is and has been quite proven in SQ competition. and any arc or sundown amp will push more than rated power even after normal voltage drop.and whats wrong with Mb QuartBy By [url=http://profile.imageshack.us/user/By [url=http://profile.imageshack.us/user/ looks just like some other amps on here to me Edited November 11, 200916 yr by corrie3232
