Posted October 27, 200917 yr Okay well i just made a pre-order on the sundown audio sae-1200 v.2 and wanted to hook it up to two 12 Fi Qs in my truck. From what i've read in some posts, I should order the dual 2 right? Or should i get the dual 1? Please help me out. Thank you.
October 27, 200917 yr Author * 1200 x 1 watts @ 1 ohm* 600 x 1 watts @ 2 ohms* 300 x 1 watts @ 4 ohms* 0.153v - 5.6v adjustable input sensitivity* 15 Hz - 250 Hz Frequency Response* > 90 dB S/N Ratio* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)* 50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover* 15 Hz - 50 Hz adjustable 12dB Subsonic Filter* 0 or 180 degree adjustable phase switch* 0 - 12 dB adjustable bass boost with 60 Hz center frequency* Wired Remote Control unit included* 5x 30 Amp Internal Fuses* 17" L x 10.6" W x 2.2" HThose are the specifications for the amp.
October 27, 200917 yr Okay well i just made a pre-order on the sundown audio sae-1200 v.2 and wanted to hook it up to two 12 Fi Qs in my truck. From what i've read in some posts, I should order the dual 2 right? Or should i get the dual 1? Please help me out. Thank you.Naw you get the dual 1 ohm version (wire each sub in series to 2 ohms and then when the wires are added together they will drop down to a 1 ohm load.
