My Current System
2 AQ HDC315-A Subs
1 XXV Maxximus
7 Kenetik 1800 Batts
Big 3 In 0 Gauge
4 Runs of Power & Ground Wire (0 Gauge) (Each)
5.5 Cb Foot Box After Displacements 38Hz w/ 2 6inch aeros
2008 Jeep Grand Cherokee Laredo SUV
270 "XP" Amp Alt From Dc Power
This spring im doing 4 18's AQ Hdc3 New Coppers Off the XXV Maxximus.
Tons of pics. Sorry some not in order
Almost done with the current system. Just need to build an amp rack.
Box Is a test box. Many to come. Trial and error. See what works best for the aq's all this power :)
Also i would love some input on this. Thanks
Edited by 08 Jeep Grand Cherokee
  • Replies 62
  • Views 8.9k
looking good.... what paint ( black ) and technique did you use for the base...... ?
nice work and nice build thread...
keep it coming
chop
keep it coming
chop
The paint? The paint color is black magic gloss (water base). White primer (water base)
Are you running wire under the car through the wheel well with no protection? If so, I wouldn't think that is a good idea. my two cents
kinda, theres rubber calking around the holes
all the cable is exposed to the elements. kinda dangerous if consider, rain, puddles, road hazzards, etc.
are u talking about the runs being under my truck? Alot of people do it. I have 8 runs from front to back. No way its going to fit under my carpet
Wow, that's a complete overhaul since September.
yes sir! Btw im geting my own termlab by spring. Im going to fine tune this beast
Im tuned in just making some :popcorn: and drinking a :drink40:, more pictures.
Looking good, I would seriously consider some rubber around those wires in the floor for the sake of safety.
Other than that looks like a lot of work. I think we have similar amps :)
I'd be more protective of those wires too. At a recent competition, someone's interior almost caught on fire because something was wrong with the wire outside the car. But good build and damn those amps are big.
I said the same thing. to each is own.
humm anyone know where i can get them rubber things? But some of the holes are realy big. so i need somthing to work. Should i put rubber pipe tubing around them at the holes?
