Posted October 31, 200917 yr Name off some high power subs (anywhere above 1000 watts RMS) with a low Fs (below 30 hz) and preferable a 15"
October 31, 200917 yr why Fs below 30hz? you know that does not have a direct effect on how low the woofer will play right? sundown audio nightshades can get low as hell, and I've heard'em do it and the 15" Fs is 41 hz or 43 depending on VC conifg.
October 31, 200917 yr Because You're Blind.15" SSA XCON D2Re 3.7Fs 31.3Qms 6.11Qes .45Qts .42Mms 268Vas 88.4Sd 810Bl 20.71SPL 89.6Xmax 31mm
October 31, 200917 yr Fi BL 15Really? Below 30hz?Let's see - Fi SSD, Fi Q, Mach5 iXL, Soundsplinter RL-p, Soundsplinter RL-s, SSA Icon, Dcons too but they don't handle 1000 watts or at least I don't think so, and the Sundown SA subs.
October 31, 200917 yr Fi BL 15Really? Below 30hz?Let's see - Fi SSD, Fi Q, Mach5 iXL, Soundsplinter RL-p, Soundsplinter RL-s, SSA Icon, Dcons too but they don't handle 1000 watts or at least I don't think so, and the Sundown SA subs.x eighty googillion.
October 31, 200917 yr Fi BL 15Really? Below 30hz?Let's see - Fi SSD, Fi Q, Mach5 iXL, Soundsplinter RL-p, Soundsplinter RL-s, SSA Icon, Dcons too but they don't handle 1000 watts or at least I don't think so, and the Sundown SA subs.x eighty googillion.Treo SSi or SSX
November 1, 200917 yr Admin Why are there no specs on Mms or Fs on the Xcon?http://www.soundsolutionsaudio.com/store/products/15%22-SSA-XCON-D1%7B47%7DD2.html
November 1, 200917 yr Author For whatever reason, when I look at the specs on google chrome (on the ssa website), they're missing, but then I go to the same link on IE and they're there.It was WEIRD...
