Name off some high power subs (anywhere above 1000 watts RMS) with a low Fs (below 30 hz) and preferable a 15"
Icon, Xcon, A Shit Load Of Subs On This Very Forum...
Why are there no specs on Mms or Fs on the Xcon?
why Fs below 30hz? you know that does not have a direct effect on how low the woofer will play right?
sundown audio nightshades can get low as hell, and I've heard'em do it and the 15" Fs is 41 hz or 43 depending on VC conifg.
Yeah, but doesn't power handling drop if you tune below the Fs?
Because You're Blind.
15" SSA XCON D2
Re 3.7
Fs 31.3
Qms 6.11
Qes .45
Qts .42
Mms 268
Vas 88.4
Sd 810
Bl 20.71
SPL 89.6
Xmax 31mm
That's strange. I've got nothing on those.
Fi BL 15
Really? Below 30hz?
Let's see - Fi SSD, Fi Q, Mach5 iXL, Soundsplinter RL-p, Soundsplinter RL-s, SSA Icon, Dcons too but they don't handle 1000 watts or at least I don't think so, and the Sundown SA subs.
Fi BL 15
Really? Below 30hz?
x eighty googillion.
Fi BL 15
Really? Below 30hz?
Treo SSi or SSX
For whatever reason, when I look at the specs on google chrome (on the ssa website), they're missing, but then I go to the same link on IE and they're there.
It was WEIRD...
