Posted November 2, 200917 yr Was wondering could this amp handle the load? It is a current MD2D by the way with the plexi bottom and stuff.
November 5, 200917 yr yes!! i ran my md1d all day at .5 never changed it the amp love dit barley got hot. i was using stock battery and stock alt. it will work perfectly fine at .5 ohms!!
November 6, 200917 yr I've heard that it can be run at .5ohms daily but if I were in your shoes I'd be pretty cautious.I've got the older MD3D (with all the terminals on the bottom) running at 2ohms to a 12" Type X and I love it. I'll never get another sub amp again.
November 6, 200917 yr Was wondering could this amp handle the load? It is a current MD2D by the way with the plexi bottom and stuff.If you used right then yes it can work the question is for how long (most amps when ran under ohm load stability it usually hurts the amp over time.
November 6, 200917 yr Author my friend decided to do the right thing and order the right subs that could be ran at 1 ohm hehe. But it is still good to know for future reference hehe.
