Everything was working fine last night. This morning i turn on the car and i can hear static coming from the woofer. I figured it was the subwoofer coil rubbing or something. Well i try 2 other subwoofers and i get the same result.
Everything seems to work fine except there's static that kind of sounds like rubbing styrofoam together. I tried everything to rule out other components and still the same result. Strangely enough the amp works fine apart from that. So i have no clue what to do now. Do i just send it in to get repaired or what? I never thought i'd have any problems with it.
Any help would be appreciated.
could be a signal issue...try swapping RCA's...or switch the output from your HU...and did you try gaining down a little to see if it goes away?
I tried everything except switching amps. I doubt that's the issue though but that's the next thing i'm trying.
i no when i was installing my equipment a couple times when my car was started and my 3000D was all installed and powered up i would connect the speaker wire into the outlet and it would make a static noise
Tried a different amp and it works just fine. I'll post a video of the issue.
Ok so i made a quick video to get a better idea of the "static" problem. This was after trying a different amp, which worked just fine.
http://www.youtube.com/watch?v=Ttd33sb8z_c
I guess there's only one thing i can do. Send it back to get fixed. Used a multimeter to check impedance and it wasn't as bad while i had it on but still there.
Well never heard that sound before
yeah i would contact Jacob or Db-r wherever you got it..
Yea i think i'll go ahead and do that. Got it from the SSA store.
how cow that is ODD
send that video to jacob or chris (at db-r) and see what they say or even ssa store for that matter! wow i never seen that before
and i was going to say a bad grounded but you even switched amps! so wow! interesting
Edited by CrazyKenKid
Found something interesting. Looks like this little guy is cracked/busted. Doesn't seem normal since it's the only one that looks this way. Wonder is this is the reason for this weird issue. Besides the noise everything works the same.
http://www.youtube.com/watch?v=TAF548VDj20
It needs repaired that appears to be a burnt zener diode.
That could easily be your problem - send it in to me w/ your purchase invoice.
Thanks for the fast response, i'll get the invoice printed and i'll send it. Where do i send it?
155 South Eastway Drive
Suite S
Troutman, NC 28166
Suite S
Troutman, NC 28166
Ok it's on it's way, sent it today. Do i need to do anything else at this point?
