November 16, 200915 yr not in a rude manner but,why would you like to know? Edited November 16, 200915 yr by mbarber25
November 16, 200915 yr HiI want to know how much is the new 12" BTL peak power. Peak power is bullstuff* that crappy companies came up with to make their woofers sound better. Burp power is different.Which are you looking for? Edited November 16, 200915 yr by DeepSubBoy
November 16, 200915 yr When it blows...that was its peak.We don't rate them on peak power..as that is just a marketing ploy...which is sort of like giving a 7 year old a can of gas and a pack of matches and telling them to not set anything on fire.
November 16, 200915 yr When it blows...that was its peak.We don't rate them on peak power..as that is just a marketing ploy...which is sort of like giving a 7 year old a can of gas and a pack of matches and telling them to not set anything on fire.haha nicely put
November 17, 200915 yr HiI want to know how much is the new 12" BTL peak power. Please read New Member Guidelines and Rules before posting again as this topic is and wont help you or others.
November 18, 200915 yr HiI want to know how much is the new 12" BTL peak power. 1.21 gigawatts, I like that.I thought this topic was as stupid as the title. Somebody close this thing.
November 19, 200915 yr When it blows...that was its peak.We don't rate them on peak power..as that is just a marketing ploy...which is sort of like giving a 7 year old a can of gas and a pack of matches and telling them to not set anything on fire.ROFLMFAO!! on a side note to the OP just scroll around the forum, there are unfortunately countless threads on BTL power-handling, try looking around first, there are more than just one page on each section.
November 19, 200915 yr When it blows...that was its peak.We don't rate them on peak power..as that is just a marketing ploy...which is sort of like giving a 7 year old a can of gas and a pack of matches and telling them to not set anything on fire.dibs for sig
November 19, 200915 yr HiI want to know how much is the new 12" BTL peak power. Peak is a sales scheme you see in store, but to figure out its true power handling only go off the RMS rating. The same goes for amps, Decks, and subs. BTW the do 2000rms, so I hope you have a nice size amp for it. '2000' watts PEAK, isnt 2000rms lol
November 20, 200915 yr If you are trying to compare the peak rating of the BTL to another companies "peak" then you should just look at the rms of both. Peak ratings are exaggerated and don't mean much of anything, so base all of your equipment off the rms so you can compare apples to apples.If you are looking at a "peak" rating to compete with box building skill and your pockets will be the biggest determining factors. I've put about 5kw rms on one for music with no issues, but some people put 10,000 watts + on them for comps.There are countless BTL power threads on this forum if you use the search function, but posting some of your goals and the reason you want to know this info may help people give you a response that will hopefully answer your question. Just beware that anything rated with just peak ratings is not worth looking into more. Best luck.
