Posted November 22, 200915 yr Hello, im making a box for my 15" Fi BL its gonna be 36 x 18 x 18 4.7 ft3 @ 30.5hrz daily driver just looking for some ground shaking fun : ) will this be a good box for that woofer?
November 22, 200915 yr Hello, im making a box for my 15" Fi BL its gonna be 36 x 18 x 18 4.7 ft3 @ 30.5hrz daily driver just looking for some ground shaking fun : ) will this be a good box for that woofer?for sure it'll bang!!
November 22, 200915 yr sure, it should work well...... the calculations i'm seeing puts the 36x18x18 at a little less than 4.7cuft though, right around 4.4 after all displacements..... that won't hurt anything though as it's still well inside the range.... I should add that this is if you're using a slot port @ 12sqin of port per cuft.... if you're going with a 6" aero then its just right.......... Edited November 22, 200915 yr by Alton
November 22, 200915 yr Author thanks for the inputi used the RE audio box calculator to get the right feq. the detentions are:Top 36 x 18 Bottom 36 x 18Left 17.25 x 16.5Right 16.5 x 16.5Back 36 x 16.5Front 32.25 x 16.5P L1 13.5 x 16.5P L2 5 x 16.5 using 3/4in MDF
November 24, 200915 yr thanks for the inputi used the RE audio box calculator to get the right feq. the detentions are:Top 36 x 18 Bottom 36 x 18Left 17.25 x 16.5Right 16.5 x 16.5Back 36 x 16.5Front 32.25 x 16.5P L1 13.5 x 16.5P L2 5 x 16.5 using 3/4in MDFNow these are all internal dimensions, right?
November 24, 200915 yr Author thanks for the inputi used the RE audio box calculator to get the right feq. the detentions are:Top 36 x 18 Bottom 36 x 18Left 17.25 x 16.5Right 16.5 x 16.5Back 36 x 16.5Front 32.25 x 16.5P L1 13.5 x 16.5P L2 5 x 16.5 using 3/4in MDFNow these are all internal dimensions, right?all measurement are in inches Edited November 24, 200915 yr by R3ap3R
November 24, 200915 yr all measurement are in inchesbut they are all the internal dimensions of the box, correct? I know that you probably know that external dimensions don't matter other than fitting it into the vehicle, but I'm just asking to be sure.
November 24, 200915 yr Author the external dimensions are 36 x 18 x 18 the port is 3.5" wide and should be 16.5" tall
November 25, 200915 yr Did you plug your external dimensions into the box calculator?Unless it asks for the thickness of the wood, then you should plug in your internal dimensions. My box is 18.5x17.75x32.5 internally, and after all displacements, it's only 4.35cuft... I didn't actually plug it into a calculator, but I'm thinkin' 4.7cuft is would be the volume if your external dimensions were really your internal dimensions. Better check that.
