Posted November 28, 200916 yr I was looking into getting a btl 18” I was wondering which option would be better a dual one or dual two ohm subwoofer??? Thanks in advance
November 28, 200916 yr Author Depends on what amplifier your using.I have two Rockford 2500 bd1 that I want to hook up to this woofer? is it ok to get them dual one ohm and hook up one amp to one of the terminals and the other amp to the other terminal??? Thanks Edited November 28, 200916 yr by portillo818
November 28, 200916 yr Depends on what amplifier your using.I have two Rockford 2500 bd1 that I want to hook up to this woofer? is it ok to get them dual one ohm and hook up one amp to one of the terminals and the other amp to the other terminal??? ThanksNO unless by some grace of god you can guaranty that both amps will put out the EXACT same amperage and voltage, you need to buy a bigger amp or just use one one of those should be about 3k that would be a good match for that sub
November 28, 200916 yr Depends on what amplifier your using.I have two Rockford 2500 bd1 that I want to hook up to this woofer? is it ok to get them dual one ohm and hook up one amp to one of the terminals and the other amp to the other terminal??? ThanksAre you going to compete, or is this for a daily setup. If for daily you dont need that much power, and if your competing I would think you already know the answer is yes.
November 28, 200916 yr Why did you make another topic about the same thing, this is . Like it was said in your other topic, just use one of those amplifiers and get a dual 2 ohm subwoofer.
