Posted December 21, 200915 yr i am buying a fi ssd 12" soon and ive been looking at alot of amps. ive heard good things about the autotek mean machine 1500d but i would like more opions before making my desicion. my budget is 150-250$.
December 21, 200915 yr i am buying a fi ssd 12" soon and ive been looking at alot of amps. ive heard good things about the autotek mean machine 1500d but i would like more opions before making my desicion. my budget is 150-250$.What voice coil option would he us too?
December 21, 200915 yr Author i am buying a fi ssd 12" soon and ive been looking at alot of amps. ive heard good things about the autotek mean machine 1500d but i would like more opions before making my desicion. my budget is 150-250$.What voice coil option would he us too?2ohm basic coil
December 21, 200915 yr i am buying a fi ssd 12" soon and ive been looking at alot of amps. ive heard good things about the autotek mean machine 1500d but i would like more opions before making my desicion. my budget is 150-250$.What voice coil option would he us too?2ohm basic coilSo you got the dual 2 ohm verison, so you need an amp that will do around 800rms or so at 1 ohm?
December 22, 200915 yr If so, this would make a great match with a touch of overhead. Plus its sundown so its hard to go wrong there.SAZ1000D refurb
December 22, 200915 yr Author If so, this would make a great match with a touch of overhead. Plus its sundown so its hard to go wrong there.SAZ1000D refurbwhat do you mean by overhead?
December 22, 200915 yr Author i am buying a fi ssd 12" soon and ive been looking at alot of amps. ive heard good things about the autotek mean machine 1500d but i would like more opions before making my desicion. my budget is 150-250$.What voice coil option would he us too?2ohm basic coilSo you got the dual 2 ohm verison, so you need an amp that will do around 800rms or so at 1 ohm?yes . so i wouldnt need a 2ohm amp?
December 22, 200915 yr An audioque AQ1200 will work with the correct settings and will also be useful if your wanting to upgrade.
December 22, 200915 yr i am buying a fi ssd 12" soon and ive been looking at alot of amps. ive heard good things about the autotek mean machine 1500d but i would like more opions before making my desicion. my budget is 150-250$.What voice coil option would he us too?2ohm basic coilSo you got the dual 2 ohm verison, so you need an amp that will do around 800rms or so at 1 ohm?yes . so i wouldnt need a 2ohm amp?Dual 2 ohm means that each voice coil is at 2 ohm. When you wire the coils in parallel it will make a 1 ohm load or if you wire them in series you will have a 4 ohm load. You can also wire the voice coils individually @ 2 ohms with a 2 channel amp and run each coil to its own channel but that is not recomended because it will most likely sound like ass.
December 22, 200915 yr If so, this would make a great match with a touch of overhead. Plus its sundown so its hard to go wrong there.SAZ1000D refurbI also agree with this. Sundown makes great amplifiers. At this price you cannot go wrong if you don't mind buying refurbrished. To be honest it is like buying a new amp because it comes with a 1 year warranty straight from sundown and that amp is also not b stock which means it looks almost new.
December 22, 200915 yr I believe Chris modifies the amps a bit to put out more power and make them more reliable, not that they are underrated or unreliable though. In fact it's quite the opposite
December 22, 200915 yr with a budget of 250, dbr has used amps with a 1 yr wanrranty . it's the Saz 1500d
December 22, 200915 yr with a budget of 250, dbr has used amps with a 1 yr wanrranty . it's the Saz 1500dKeywords being for an ssd
December 22, 200915 yr with a budget of 250, dbr has used amps with a 1 yr wanrranty . it's the Saz 1500dKeywords being for an ssd there's nothing wrong with to much power, he just has to use the thing between his ears, when his playing music Edited December 22, 200915 yr by corrie3232
December 22, 200915 yr Author thanks for the info im prob gonna get that saz1000d its the perfect price i dont mind that its refurbed as long as it has a warranty im good. but i went on dbr and couldnt find any saz100d's Edited December 22, 200915 yr by mustangsub
December 23, 200915 yr 1500 watts is not too much for SSD in the right enclosure. What are your goals and listening preferences?
December 23, 200915 yr Sorry dude... I just bought it... but I think the SAE-1200D is still there. Only a few bucks more and so long as you don't go crazy with the gain knob, it'll be a good match.
December 23, 200915 yr thanks for the info im prob gonna get that saz1000d its the perfect price i dont mind that its refurbed as long as it has a warranty im good. but i went on dbr and couldnt find any saz100d'sask them if you can get a rain check
December 23, 200915 yr 1500 watts is not too much for SSD in the right enclosure. What are your goals and listening preferences?The 1500 is putting out close to 1800w and you wont hear a difference with that driver accept when it extends beyond its mechanical limitations. Unless you are doing a competition the 1000 or 1200 is fine. Why spend an extra hundred if it is unnecessary?
December 23, 200915 yr I never said anything about the sundown 1500d amp. I am just saying 1500 watts in general. I was going to suggest another amp but I doubt the OP would go with it anyways.
December 23, 200915 yr I never said anything about the sundown 1500d amp. I am just saying 1500 watts in general. I was going to suggest another amp but I doubt the OP would go with it anyways.Most likely not. This is a sundown dominant forum and you will be considered crazy to prefer another amp.
December 23, 200915 yr Don't get me wrong, if I had the money, I'd go with sundown though but I would get the SAZ.
December 23, 200915 yr Author 1500 watts is not too much for SSD in the right enclosure. What are your goals and listening preferences?my goals are for the sub to get moderately loud in my convertible soft top and i listen to alot of rap so its mostly boomy bass .
December 23, 200915 yr Author Sorry dude... I just bought it... but I think the SAE-1200D is still there. Only a few bucks more and so long as you don't go crazy with the gain knob, it'll be a good match.yea ive heard that. and btw nice box
December 23, 200915 yr what is the biggest volume you can get into your trunk? I just did a build for a convertible and its not gone any room at all.
