Posted December 26, 200916 yr i am getting a 15" Fi Audio SSD15 sub and i am wondering what amp i should get. i dont know if i should get one with 800 rms or 1000 rms. also, what are the best specs for this sub? Also, will i have to do the big 3 or anything else to handle this wattage? i have 98 navigator. thanks!
December 26, 200916 yr SAZ 1000D would be a good match for the SSD. I would recommend doing the big 3,
December 26, 200916 yr i am getting a 15" Fi Audio SSD15 sub and i am wondering what amp i should get. i dont know if i should get one with 800 rms or 1000 rms. also, what are the best specs for this sub? Also, will i have to do the big 3 or anything else to handle this wattage? i have 98 navigator. thanks!This could be a good amp. sae1200D Just watch the gains and the volume. X2 on the big 3. Look at the site for all the spec info. It will tell you what you are asking.
December 26, 200916 yr Author DANG! I really didnt want to have to do the big 3!! what is the most wattage i can push without going the route of having to do the big3?
December 26, 200916 yr DANG! I really didnt want to have to do the big 3!! what is the most wattage i can push without going the route of having to do the big3?We are only recommending it. The big 3 is such an easy way to boost your electrical.
December 26, 200916 yr The "big 3" is not difficult, and it does nothing but help you. I recommend doing it as well. I do not agree that the SAE 1200D is for you, I say you would be better off with the SAZ 1000D. Just don't get too happy with the volume knob, set your gain and filters correctly, and you'll be in great shape.
December 26, 200916 yr The "big 3" is not difficult, and it does nothing but help you. I recommend doing it as well. I do not agree that the SAE 1200D is for you, I say you would be better off with the SAZ 1000D. Just don't get too happy with the volume knob, set your gain and filters correctly, and you'll be in great shape.The only reason I recommended that was because there isnt any refurb 1000s left. Unless you can find one used frm a member or something.
December 26, 200916 yr oh ok. but does it cost a lot of money to upgrade it?It's much cheaper to do it yourself, buy some welding wire, terminals, and follow the instructions here: and your done.
December 26, 200916 yr oh ok. but does it cost a lot of money to upgrade it?No, just measure out how much 1/0 wire you need. Alternator to positive battery terminalengine block to chassis negitive terminal to chassis...thats all, check out Knu Konceptz
December 26, 200916 yr oh ok. but does it cost a lot of money to upgrade it?No but it is a cheaper upgrade then buying a battery or alternator, and a smart thing to do if you want to keep your vehicle or something for a long time. You should also get a voltmeter to keep an eye on your voltage?Next time give a budget so someone can help you better and find an amp that fits your needs?DANG! I really didnt want to have to do the big 3!! what is the most wattage i can push without going the route of having to do the big3?A big 3 does not determine how much voltage you can run, a car's factory system such as alternator and battery will determine that. The Big 3 makes running extra power and accessories easier without slowing down your car's factory electrical system. Since every car is different, nobody can tell you what the general amount of extra watts you can run off of a stock system.
