OK so I ordered 2 Fi BL 18"s and I just really hope I can put them in my 96' Blazer. But I don't know the dimensions for a ported box are. So if anyone can please help i would appreciate it a lot thanks!
what are your max dimensions? Ported box we recommend using 5-8 cubic feet @ 30-35Hz tuning, you can tune a little higher if you wish but we recommend keeping it close to 32hz for a daily driver. Again the same 12-16 square inches of area applies per cubic foot of volume.
The dimensions are on the same website that you purchased your sub from, you should of measure your max dimension before you bought to 18"s to make sure they even fit :Doh:
I hope you are joking cause this is the backasswards way of doing it.
Anyhoo, you should measure the max dimensions of your blazer and come back with that. Then you can start planning an enclosure size and all that.
