I hope you gave that poor car some beefier suspension, ha.
nope something will be done about that later tho
  • Replies 69
  • Views 6.6k
  • Damn I accidentally rated the topic with two *. Sorry for that. Build looks awesome !
well everything is hooked up and working. got the mids/highs tuned. have not messed with the subs because its too late at night to do it. but im happy so far. still have hours i could sit and tune the mids and highs but i think ive got them close. i took a vid of the mids and highs but i think i had my hand over the mic with the flashlight in my hand so it sounds kinda muffled. for some reason there is some rediculous turn off pop/squelch im not exactly sure what is causing it but im not a big fan of this eclipse dvd navi headunit. does not have enough adjustments for things.
doors before we put them back on. they are not getting finished by me but they will do for now.
so i got the subs loaded and hooked up and dropped the carpet and everything in.
ok the vid
How do you like that front stage? Is it worth the money? Does it keep up good with the wall ?
x2?
Congrats, it looks like you've rounded third base. SWEET
wile I have yet to hear it I allready know its worth it and will keep up since its accualy Pro audio stuff its quite effieient and on top of that there is somewhere around 1000 watts bettween the 2 doors
Edited by loudcav
couple quick tests playin bass mekanik - bass mekanik. also played around with a few other songs and it was doing over 150 from 35hz to 55hz. i was doing the same number at 44hz and 52hz from 2 songs i played. :) this thing plays 30hz like there is no tomorrow. cant wait to let nick show this thing off at sbn. ill get vids sometime this weekend probably. hope nick comes by and checks my masterpiece out :)
sealed on dash on bass mekanik
drivers door open on bass mekanik
looks good and putting up good numbers.....congrats and my hat is off to you
I would have thought closer to 55. What's your goal?
Dash metering is very sensitive to port placement -- in the middle like that doesn't hit the dash the best. But the port would not have fit in this car to one side (best on the meter).
it also isnt 100% dialed in you also have to remember tho that those scores were done on music with a tone it would probably do a bit better number but it wasnt exacly built to be metered we built it to play music and demo
well i took some videos tonight so its a little dark but u can kinda get the idea of it.
vid of just the system.
sub movin :)
GO COLTS!
lookin sick!
Sounds like it is going to be a beast.
still havent charged the batteries and been beating on the subs alld ay i decided to put the meter on it again :)
30hz :)
45hz :)
there is an EASY 154 in this once we get some things tuned in and a better headunit.
Any input on those Selenium Horns and 8"(is it the 8W4P 8" woofers) speakers? Im looking to do an 8" and horn setup and looking at these two speakers as an alternative to what I want, so any reviews or remarks on the sound or what you like about them. What do you have those 8" crossed at and about how power are they seeing? Thanks
they sound great and you are correct on the model the 8s are bridged at 4ohms on one of the 100.2s so roughly 200 watts a piece not sure what its all crossed over at it will mostly depend on your taste honestly with a good EQ/ crossover the PA stuff can sound good which is mainly why they work well in the car the Audio control DQXS has control over hem
Thanks for the insight.
