Posted January 17, 201016 yr I can either get a second SAZ-2000 or a single SAZ-3500. I am leaning more towards getting the second SAZ-2000 so I can have more power. But I like the thought of having a single powerful amp. But on another note, I am VERY impressed with the 2000, it does more then rated power all day without getting more then luke warm. my SAX-100.4 gets warmer then the 2000 does. These will be powering two RE MT 18"s
January 17, 201016 yr Now that is a touch choice, your gonna have to let it boil down to a compromise either 500 watts more power or just one amp with less wiring. Which will you choose?
January 17, 201016 yr Author Now that is a touch choice, your gonna have to let it boil down to a compromise either 500 watts more power or just one amp with less wiring. Which will you choose?I would have to say it's more then a 500rms difference though, as in tests the 2000 did 2400 with mid 12's above 1ohm. I run mid 13's and wire below 1 ohm So I would call it almost a 1000rms difference.
January 17, 201016 yr I doubt it is that big of a difference, have you ever tested a 3500D to even know what it is pulling to do a comparison (I would go with 500 watts give or take some). If your not competing then I would get the 3500D but if you are then just buy the second 2000D since you already have one of them.
January 17, 201016 yr Author I doubt it is that big of a difference, have you ever tested a 3500D to even know what it is pulling to do a comparison (I would go with 500 watts give or take some). If your not competing then I would get the 3500D but if you are then just buy the second 2000D since you already have one of them.Hmmm idk man lolI do compete whenever there is a comp. I guess another 2000 will be what I do.One more question, do I run .5 ohm per amp or .7ohm per amp?
January 17, 201016 yr if you are asking wiring configs for 1 sub per amp, then dual 2s will be wired to 1 ohm which can read anywhere between - 0.65-0.9ohms
