Posted January 19, 201015 yr Does anyone have an idea of about how many amp the 1500d pulls at 1ohm while going from 14.4 to around 13 volts
January 19, 201015 yr 115.384615 @ 13v watts divided by volts = ampsamps times volts = watts Edited January 19, 201015 yr by Julian
January 19, 201015 yr Yeah...I could tell you. So could an Algebra book.LOLSignatured Edited January 19, 201015 yr by Julian
January 19, 201015 yr Yeah...I could tell you. So could an Algebra book.LOLSignaturedSean deserves the credit Check MY signature.
January 19, 201015 yr 115.384615 @ 13v watts divided by volts = ampsamps times volts = wattsThat is assuming 1500w output and 100% efficiency ?
January 19, 201015 yr 115.384615 @ 13v watts divided by volts = ampsamps times volts = wattsThat is assuming 1500w output and 100% efficiency ?+1 ..
January 19, 201015 yr The fuse rating is a fairly accurate "max" current draw figure for most reasonable application -- drop the amp lower and it will draw more than that.
