Does anyone have an idea of about how many amp the 1500d pulls at 1ohm while going from 14.4 to around 13 volts
Yeah...I could tell you. So could an Algebra book.
Civic, I was being sarcastic FYI ;)
LOL
Signatured
Sean deserves the credit ;) Check MY signature.
115.384615 @ 13v
watts divided by volts = amps
amps times volts = watts
That is assuming 1500w output and 100% efficiency ?
+1 .. :noob:
The fuse rating is a fairly accurate "max" current draw figure for most reasonable application -- drop the amp lower and it will draw more than that.
