November 21, 201114 yr Hope this dosent happen to my camaro... Mark and I will need to talk. lolThey broke my junk and my money is on the zcons raping the hell out of your car too.
November 21, 201114 yr Hope this dosent happen to my camaro... Mark and I will need to talk. lolThey broke my junk and my money is on the zcons raping the hell out of your car too.Oh My!! Maybe ZCONs need to come with a coupon for re-inforcement metal??
November 22, 201114 yr Admin Dylan, can a replacement patch be welded? Hard to tell if that damage will shear across the window line or not, from here.
November 27, 201114 yr Rust + Bass = destructionto think it started out with no rips in the roof makes me sad. Still debating on how to fix it. but it will get fixed one way or another.
November 27, 201114 yr get some sheet metal and weld over it..sounds easy, but the metal on a geo metro is about as thin as it gets, very difficult to weld to without blowing through. doable but, with the welder we borrowed not even a friend of ours (went to school for welding) could do it. Im looking into some type of panel epoxy type stuff, and doing a few layers to the outside of the car.
November 27, 201114 yr get some sheet metal and weld over it..sounds easy, but the metal on a geo metro is about as thin as it gets, very difficult to weld to without blowing through. doable but, with the welder we borrowed not even a friend of ours (went to school for welding) could do it. Im looking into some type of panel epoxy type stuff, and doing a few layers to the outside of the car.Roll some sheet metal into a U shape and put it on front and back then seal with some kind of sealant would maybe work.or go all chop shop and find one local and cut the roof off of it and weld it back on the Geo
December 23, 201114 yr Did some fixing and upgrading in the geo a few weeks back. Little geo is back to being loud again.some testing on music, car off.
December 27, 201114 yr get some sheet metal and weld over it..sounds easy, but the metal on a geo metro is about as thin as it gets, very difficult to weld to without blowing through. doable but, with the welder we borrowed not even a friend of ours (went to school for welding) could do it. Im looking into some type of panel epoxy type stuff, and doing a few layers to the outside of the car.ah ok. ya i should of thought about how thin the roof was... my civic's roof is pretty thin... but not as thin as a geo lolcrazy numbers bro... shit looks insane i wish i could hear it
February 9, 201313 yr numbers on the 3500s on 4 batteries was153.7@24hz154.1@25hz155.7@27hz156.4@34hz156.8@37hz156.9@41hz157.2@43hz156.9@45hzput two 5500s in there off the same 4 batteries.154.5@25hz155.9@27hz156.5@28hz156.7@29hz156.7@30hz156.8@31hz156.8@37hz157.5@40hz158.2@40hz158.4@41hz158.4@42hznow just need more batteries and should get a little louder.numbers are on the dash door open by the way.
February 10, 201313 yr numbers on the 3500s on 4 batteries was153.7@24hz154.1@25hz155.7@27hz156.4@34hz156.8@37hz156.9@41hz157.2@43hz156.9@45hzput two 5500s in there off the same 4 batteries.54.5@25hz155.9@27hz156.5@28hz156.7@29hz156.7@30hz156.8@31hz156.8@37hz157.5@40hz158.2@40hz158.4@41hz158.4@42hznow just need more batteries and should get a little louder.numbers are on the dash door open by the way.Quoted this just so we could like at this list a second time!
