  • Replies 56
  • Views 22.9k
  • Google Sketchup
  • Try this one: http://www.soundsolutionsaudio.com/index.php/downloads/enclosure-designs.html
  • Mark LaFountain
    Mark LaFountain
    These pages are found under the respective product you are looking for now. a tab that says "pre-designed enclosures". http://www.soundsolutionsaudio.com/index.php/product-information/icon.html > "
:woot: much better than re's calculator...too bad those wont work for my nightshade...but great work, they look awesome.
:dancing: :dancing: :dancing: :dancing: :dancing:
  • 8 months later...
Updated the link.
what do i need to open the file?
Google Sketchup
Google Sketchup
alright, i downloaded that, now i can see the pics of it but no measurements
Google Sketchup
Did you extract the zip file after you downloaded it?
  • 2 months later...
:dancing: awesome... used WinRAR to view it... worked like a champ. Thanks for the post!
  • 4 months later...
Any recommendations for the ZCON subs?
Especially the 15"?
I will get those done soon. They will be a little smaller then the Xcon for a point of reference, but for the most part you can use Xcon designs.
Ok thanks a lot. Because I'm going to help a friend build a box for one.
And I forgot to ask, what would the mounting depth be, couple of inches more then Xcon?
  • 3 months later...
I clicked on the link for enclosure designs. I do not see any indication that seperates the various enclosure designs with specific SSA product lines :ughdunno:
Ah, that did work :)
:thanx:
  • 1 month later...
why no 15 inch dcon :ughdunno:
2.75 - 3.5 cubes @ 33hz.
could i just follow a different 15 inch download from the site?
The Xcon 15 enclosure design is a little on the larger side for the Dcon 15, but you can still use it as a base.
Any ZCON designs going up soon?
And i was also wondering when to use the optimal specs. Every I have gone to suggested not going bigger than 2.5ft^3 per sub for the zcons.
Edited by brownm3
After Mark is back, the enclosure designs and more downloadable 3D models will be going up. If you have a specific enclosure question before then, shoot me a PM and I will help you.
The Xcon recommendations are a good spot to start with the Zcons except no for sealed enclosures. What type of power are you running brownm3? and what size and how many zcons?
I have the 12"s and I be powering them with 5000 watts.
