Posted February 10, 201015 yr Admin You Can find all the info needed for this subject at the below URL Enclosure Designs
February 10, 201015 yr much better than re's calculator...too bad those wont work for my nightshade...but great work, they look awesome.
November 8, 201015 yr what do i need to open the file?Google Sketchupalright, i downloaded that, now i can see the pics of it but no measurements
November 8, 201015 yr what do i need to open the file?Google Sketchupalright, i downloaded that, now i can see the pics of it but no measurementsDid you extract the zip file after you downloaded it?
June 15, 201114 yr Admin Any recommendations for the ZCON subs? Especially the 15"?I will get those done soon. They will be a little smaller then the Xcon for a point of reference, but for the most part you can use Xcon designs.
June 15, 201114 yr Ok thanks a lot. Because I'm going to help a friend build a box for one. And I forgot to ask, what would the mounting depth be, couple of inches more then Xcon?
October 14, 201114 yr I clicked on the link for enclosure designs. I do not see any indication that seperates the various enclosure designs with specific SSA product lines
October 14, 201114 yr I clicked on the link for enclosure designs. I do not see any indication that seperates the various enclosure designs with specific SSA product lines Try this one: http://www.soundsolutionsaudio.com/index.php/downloads/enclosure-designs.html
October 14, 201114 yr Admin I clicked on the link for enclosure designs. I do not see any indication that seperates the various enclosure designs with specific SSA product lines Try this one: http://www.soundsolutionsaudio.com/index.php/downloads/enclosure-designs.html
December 6, 201114 yr Admin could i just follow a different 15 inch download from the site?The Xcon 15 enclosure design is a little on the larger side for the Dcon 15, but you can still use it as a base.
December 7, 201114 yr Any ZCON designs going up soon? And i was also wondering when to use the optimal specs. Every I have gone to suggested not going bigger than 2.5ft^3 per sub for the zcons. Edited December 7, 201114 yr by brownm3
December 7, 201114 yr The Xcon recommendations are a good spot to start with the Zcons except no for sealed enclosures. What type of power are you running brownm3? and what size and how many zcons?
December 7, 201114 yr Admin After Mark is back, the enclosure designs and more downloadable 3D models will be going up. If you have a specific enclosure question before then, shoot me a PM and I will help you.
December 7, 201114 yr The Xcon recommendations are a good spot to start with the Zcons except no for sealed enclosures. What type of power are you running brownm3? and what size and how many zcons?I have the 12"s and I be powering them with 5000 watts.
