  • Replies 287
  • Views 39.4k
  • Thanks. I spent most the day working on it. Attached the end caps and added some 2x4 pieces to reinforce the joints. I also added some trim pieces for looks on the rear brace. Started doing some of
  • Nice start!
  • Look like a good build.
Sorry to hear about that bat, had one a few years ago blow close to me and the noise is enough to make you go check your pants!
Great work on the frame!! can really see it taking shape and tough/strong is not a question anymore...
Thanks.
It was loud thats for sure.
WOW!
Holy Hell man you have some serious skills.
Great Job!
:drink40:
Thanks guys.
way to avoid the crack about messy pants. looks like this little mishap scared you more than you'll admit
:ehh:
i like this build.
:ehh:
i like this build.
It surpised me a bit but I had a hat and hoodie on so the sound was muffled a bit. It would have been way worse if it was summer time and I was working in a T shirt.
Got the other inside plated.
Started plating the top rail.
All the plates meet edge to edge to create an outside corner. The goal is to leave no gap or as little gap as possible. This gives the best weld for polishing down to a rounded edge without grinding all the weld away.
Just stitched welded for now until I get the rest of the plates done.
Finished the other side top plate.
I didn't point out that all the body mounts opeingns are being cut to allow the bushing to sit on the reinforcing plates to prevent them from sagging in over time.
I added the plate to tie the rear arch plates together for a cleaner look. I still need to finish shaping it though.
Got the bottom edge trimmed up and tacked in place.
Also trimmed all the lower edge of the arches down and blended them into the rear bar.
You can see in this pic that I've left the plates over sized towards the rear. That will be the new shape of the frame since I don't like the shape of the factory tail section.
The factory shape of the middle of the arch pinches in at the bottom. I'll be reshaping that area also. The new plate is close to the new shape in this pic and will give me a much stronger and cleaner arch section when finished.
I was on a roll so I just moved on to the front frame horns and trimmed those down also.
Welded a washer and nut to the frame to make a captive fastener that can be plated over.
Also made some over sized reinforment washers to prevent the frame from cracking.
Made a mid plate for the crossmember using 1/4" plate.. It slides through the bottom and out the top creating an I beam of sorts. It will be welded on both sides and the reinforcment plates will get plug welded to it also for maximum strength.
Decided I didn't like how this section was looking so out came the cut off wheel.
Then I made up some new mount flanges out of 1/4" plate and made a 1/2" thick slug to give the bolt opening more surface area so the hole won't oval out.
It is welded to the top of the crossmember now to eliminate the void behind it like the factory mount has. This also allowed me to tie into the "I" beam plate. I should also be able to tie the new mounting flange into the coil pocket sleeve now.
Made a new curved section out of 3/16" to replace the factory section I cut out. Also got the rear of the crossmember plated but it still needs final trimming. Notice the radiused corner where the crossmember meets the side rail, there will be very few hard corners if all goes to plan.
Got the other mount done and moved onto plating the bottom.
Here's one of the mistakes I spoke of earlier. I didn't get the corner piece lined up properly and it was not coming back off by the time I noticed. Not a big deal though. I just cut a filler piece to take up the gap and bevelled it like a but joint. This is a far better option that just filling the void with weld.
Also dropped the coil pocket sleeve in and welded it up.
I was able to tie it into the midplate as well.
A little sneal peak of how it's going to look once I get everything plated, trimmed, and polished down. It going to be super clean.
Dam my garage is a wreck. :(
You must hate your rear window, because it's gonna get abused.
man this looks amazing..perfect welds and great attention to details
Wondering if the overall height of the frame is shorter or if you are body dropping.
Yes it will. :woot:
Thanks. I've been welding for almost 20 years now so I've had a bit of practice.
The bottom of the frame hangs down lower on the stock frame at the firewall. The mods I've done will now make the lower edge of the frame thats visible even with the rocker instead of hanging lower up front.
Made a new curved section out of 3/16" to replace the factory section I cut out. Also got the rear of the crossmember plated but it still needs final trimming. Notice the radiused corner where the crossmember meets the side rail, there will be very few corners if all goes to plan.
Plated the other side and started working on the other lower control arm bracket.
Used the jig to get everything lined up and then welded it up. I still have some more to do to make them stronger and better looking.
Did a little more work on the mounts today. I want to keep as much of the fasteners hidden as possible for a cleaner look.
I'll be dressing up the other side of the bracket as well.
Got the other half of the mount just about finished. I need to build up some low spots with weld and do a final polish still. The head of the bolt will be counter sunk now.
The front mount is taking shape. Everything still needs a bit of metal finishing but it's close.
I had to take a break from the brackets so I went ahead with plating the under side of the frame horn before moving to the other side.
I'm real pleased with how smooth it's starting to look.
Looking killer as usual. Can't wait to see how the suspension comes out! :popcorn:
I know it's already been said bro....but KILLER work :drink40: I can't wait to see how this all comes together :popcorn:
Thanks guys. I'm changing my plans a bit for the suspension. Not going the round tube route, going to hand fab everything from plate steel.
More progress.
Other side is all tacked in place and almost finished.
Here is a pic of how the bolt will be flush mounted.
Also rounded the corners off a bit more to help the bottom flow nicer into the mount pocket.
Outhopu.......Seriously SUPER craftsmanship.......i am very impressed with you metal skillz......keep it coming bro.....that chassis is gonna look slick as hell when your done.....
Thanks guys.
I've been tied up lately but managed to get a bit done. Like I said before I'm going to use as little filler as possible so it's my goal to get all the corners nice and square to allow me to shape the steel instead.
Plated the bottom of the crossmember but still need to trim the front edge after I flip it back over. Everything still needs more metal finishing but thats for a later date.
Went ahead and sleeved some of the body mounts for a change of pace.
Working on a cap/plug to keep things smooth. I may have a simple and cost effective methode figured out.
Started getting the bottom arch plated tonight.
Got the other arch bottom tacked on. I'll be working on the rear piece tonight to tie everything together.
Laid down a nice fat bead into the bevell for good penetration and to get the bead high enough to allow me to polish it down nice and flat without doing multiple passes.
Got the back piece done tonight.
  • 2 weeks later...
Just about got the rest of the bodymount openings cut out and sleeved. I'll get the last 2 tomorrow then trim and flush them all.
Plated the front of the crossmember but still need to trim the top edge once I flip it. I got the lower edge real close to it's final shape. I pinched the nose down a bit more to be sure it won't bottom out.
Flipped the frame and finished trimming the crossmember plate.
Then got started on the top arch plate.
Making sure to keep it tight with minimal gaps.
Got the other arch plated and trimmed the rear section down. Still need to cap the top of the rear cross bar.
Almost done plating the rear. I have a couple small filler pieces and I'll have to get the very back piece done after I take it off the table.
Got started on the top front again today.
One side tacked on.
I did some plug welds to tie the plate into the donut underneath and to the crossmember where it meets the coil pocket.
Also added the inside trim piece to clean up the looks and give it the radiused corner. Still needs a little trim work but it's close.
Finished the last filler piece on the right frame horn. Don't mind the nasty paint and rust. I cleaned the weld area. The entire frame is getting blasted when I'm done with it anyways.
Plated the other top side rail
Then made the filler pieces.
I still need to do a bit more where the steering shaft recess is thats why the plates don't line up. I'll get that after plating the top of the crossmember.
so, i might have missed it but... where is the body during this?
This was an extra frame we picked up to build so the car it's for isn't completely torn down yet. I stripped the sounds and interior out of it but the rest of the car is still together.
love the look from the back window!!
Wow didnt reliaze what page i was on!!
Edited by sound=vibration
Just flat out excellent work. Keep it up. :)
Too cool.....this chassis is a work of art......if i ever built a hopper you would be the man i would want doing my chassis....
the more i look at this, its an amazing build so far. love the build of the frame
Thanks guys.
Full welded and polished the top of the spring pocket so I could get started on the new upper ears.
It's got to be nice a crisp. ;)
Used 1/4" plate for these.
Got the outer tabs done on the other side so I could pull the jig and plate the crossmember.
Cleaned up the edges before plating.
I didn't get too far on this, should get it done tomorrow.
