Posted March 25, 201016 yr I have spent an hour on google searching trying to find a neon light controller that will flash to the music using a rca cable so the neon flashes to the music and not people talking. I have seen them before but i cannot seem to locate one now that I wan't to get one.
March 25, 201016 yr When I had neon lights I would just take the plug in part off and split the two wires from each other. I would wrap one wire around my remote start wire and put it in the remote start terminal on the amp and the other wire was wrapped around the ground wire and place in the ground terminal. This made my neon go to the beat, hope that makes sense and helps. Just make sure your neon has the blinking feature.
March 25, 201016 yr Author well that shouldn't make ur neon blink unless ur voltage is dropping that much in ur remote wire.
March 25, 201016 yr I did mine to the speaker wire i believe it was. I was over 10 years now, so i am not very sure!!
March 25, 201016 yr well that shouldn't make ur neon blink unless ur voltage is dropping that much in ur remote wire.If you have a neon that has the blinking feature on it, then it will.
March 25, 201016 yr Author that could kind of work, but its not proper, I have seen these neon control box that at the time where $40-$60 and let u plug in a rca cable and you could hook multiple neons to it so they would blink perfectly to the music, and so that it wouldn't blink every time a door was closed.
March 25, 201016 yr Author o ya well ya the blinking feature but all that is is a microphone, which also blinks to people talking doors closing and such I don't want that.
March 27, 201016 yr Author huh, I am but what would a neon have anything to do with sound quality, it won't affect the way anything sounds. if your referring to the rca jacks, I would hook it up to the output jacks on my subs amp. so it won't affect anything.
March 27, 201016 yr Author i was thinking of that but they don't have a uniform light i want this to be perfect because once i put this in the box i plan to never take it out.
