Im looking for some peoples opinions on what to run to my bl 12 at 2 ohms.?
comments are very welcomed
Budget? Do you have either of these amplifiers?
thats the thing for he kicker im looking for a discounted price around 500 or less like you can find amazon and what not but 450 is what i reallly want to stay at.
i use to have the 1600 brutus but then it got stolen out my truck.
I would say go Kicker! Just not a fan of Maxxsonics! Kicker has always made a quality amplifier!
I don't think the brutus does 1700 at 2ohm, i think they put out that much power at 1 ohm, so if you would connect it at 2ohm then you would give the BL max. 850W.
And the kicker does 1500w at 2 ohm.
So i would take the Kicker.
Kicker.
MaxxSoincs can lick my nuts.
lol i liked my brutus, but i liked my zx1000.1 more.
I like Maxxsonics.
Both of my amps do what they are supposed to do and more.
That said, get the Kicker because as stated above they do rated at 2ohm.
So I was just looking at the sundown 1500 which of those would you reccomend between the kicker and sundown?
The SAZ-1500D does it's power at 1 ohm, not 2.
The kicker just because it gives you the power you need at the ohm load you will be wiring your sub to.
........... apparently you don't understand ohm load. the sundown will do rated at 1 ohm and the kicker at 2 ohm. so think for a minute about that question
No no I get it I was just asking because I ordered my bl so I'm able to change it to 1 ohm if I'd like.
500's for 1500 watts at 2...
you can get an alpine m2000 for 420 brand new
You'll have to recone to change to dual 1.
between those two amps i would do the kicker
thanks gurs appreciate the inputs. i ended up ordering the 1500
No problem man, I just ordered an amp and headunit myself as well. Post pictures of your equipment when it comes :fing34:
sounds good man, you too! :woot:
