Posted April 16, 201016 yr Ok i need some help on picking out the amp for my Fi BTL fully loaded i have to amp choices tell me wich one you think is better or if neither of them ar good Amp 1. XT4000DE V2 1,500 watt RMS (4000w peak) mono car amplifier Class "D" fully digital power supply4000 watts peak output1,500w x 1 RMS @ 1 ohms800w x 1 RMS @ 2 ohms500w x 1 RMS @ 4 ohmsBridgeableEfficiency: 86 % @ 4 Ohms or 84 % @ 2 Ohms or 76 % @ 1 ohmFully adjustable butterworth low pass crossover filterLow Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octaveAdjustable Bass Equalizer: 30 dB Bass Boost @ 45 HZSubsonic Filter: 15-40 HZ @ 24 dB per octaveLow level InputRCA Pre-amp outputPass through output for multiple amp installsBlock Power ConnectorRequires true 0 gauge power wire for installationScrew terminal barrier strip speaker connectors8 - 18 AWG speaker connector gaugeAluminum heatsinkConvention coolingpower and protection LED IndicatorsClass DFrequency Response: 20 HZ - 500 HZWeight: 13 poundsDimensions: 1.875" x 10" x 15.75"» Product Specifications CEA Compliant No Channels Mono (1 channel) Class Class D Condition BRAND NEW IN ORIGINAL PACKAGING Continuous Power at 1ohm (Mono) 1301- Up Continuous Power at 2ohm (Mono) 601-800 Continuous Power at 4ohm (Mono) 451-600 Fan Cooled Yes Fuse Rating N/A Manufacturer US AMPS Max Input Gauge Size 0 Minimum Impedence 1 ohm Peak Power 3001- Up Remote Bass Knob Yes THD at Rated RMS <1% Warranty 1 YEAR Amp 2.5000 Watts Digital Mono Block Amplifier 1 Ohm Stable Max Output Power: 5000 WATTS @ 1 OHM 1900 watts RMS @ 1 Ohm 1600 watts RMS @ 2 Ohm 1400 watts RMS @ 4 Ohm High Current Amp More Efficiency than other Class D Amp Designs Class D Digital, Monoblock Built in low pass crossover filter Crossover Slope 24DB per Octave Input Sensitivity Control (6V to 0.2V) Bass Equalizer Control (0 - 18 dB) Bass Frequency Control Phase Control (0 - 18 0degrees) Subsonic filter Bass EQ frequency : 40 HZ - 120 Hz Bass Boost - 0 - 18 dB Wired Bass Remote Control Gold Plated Terminals & RCA 0 Gauge Power terminal High Efficiency Low Heat Emission High Damping Factor For Improved Bass hits Uses Less Energy from the car battery, so your lights don't need to dim, and you can still have a lot of power! Real 1-Ohm stability means this amp will stay cool, after pounding for days straight, with 2 dual voice coil 4 ohm subs running down to 1 ohm. Other amps may say 1 ohm stable, but this one is truly 1 ohm stable! Includes free fuse holder + bass knob Thanks For The Help
April 16, 201016 yr Seriously?If it is important to you, take your time and give more info.I am not looking that shit up just to take a guess because you are lazy,
April 16, 201016 yr Yeah, what kind of amps are they? You have a 1500 watt and a 5000 watt up there, maybe you should look at something in the middle. I've got a RF T1500-1bd for my BTL 18. I might end up getting a T2500 in the future, but I think the 1500 should do fine.
April 16, 201016 yr The XT4000 is a Us amps. Xterminator series. It even says it in the post We need to know what the other amp is, specifically. Not just the power ratings.
April 16, 201016 yr Yeah, what kind of amps are they? You have a 1500 watt and a 5000 watt up there, maybe you should look at something in the middle. I've got a RF T1500-1bd for my BTL 18. I might end up getting a T2500 in the future, but I think the 1500 should do fine.careful here its a 1500 rms amp and a 1900rms amp but idk what quality brand it is so
April 17, 201016 yr Seriously, any company nowadays who still list power ratings by peak power... i'd skip that choice.
April 17, 201016 yr Author Seriously, any company nowadays who still list power ratings by peak power... i'd skip that choice.theese are the ampss http://www.audiosavings.com/products/Mono-Car-Amplifier/PERFORMANCE-TEKNIQUE-5000w-MONO-POWER-AMPLIFIER-CAR-AMP/ICBMSUPER.aspxhttp://www.audiosavings.com/products/Mono-Car-Amplifier/NEW-US-AMPS-XT4000DE-V2-4000-WATT-MONO-CAR-AMPLIFIER/XT4000DE+V2.aspx If you got any ideas for amps send me the links
April 17, 201016 yr Author Ok i need some help on picking out the amp for my Fi BTL fully loaded i have to amp choices tell me wich one you think is better or if neither of them ar good Amp 1. http://www.audiosavings.com/products/Mono-Car-Amplifier/NEW-US-AMPS-XT4000DE-V2-4000-WATT-MONO-CAR-AMPLIFIER/XT4000DE+V2.aspxXT4000DE V2 1,500 watt RMS (4000w peak) mono car amplifier Class "D" fully digital power supply4000 watts peak output1,500w x 1 RMS @ 1 ohms800w x 1 RMS @ 2 ohms500w x 1 RMS @ 4 ohmsBridgeableEfficiency: 86 % @ 4 Ohms or 84 % @ 2 Ohms or 76 % @ 1 ohmFully adjustable butterworth low pass crossover filterLow Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octaveAdjustable Bass Equalizer: 30 dB Bass Boost @ 45 HZSubsonic Filter: 15-40 HZ @ 24 dB per octaveLow level InputRCA Pre-amp outputPass through output for multiple amp installsBlock Power ConnectorRequires true 0 gauge power wire for installationScrew terminal barrier strip speaker connectors8 - 18 AWG speaker connector gaugeAluminum heatsinkConvention coolingpower and protection LED IndicatorsClass DFrequency Response: 20 HZ - 500 HZWeight: 13 poundsDimensions: 1.875" x 10" x 15.75"» Product Specifications CEA Compliant No Channels Mono (1 channel) Class Class D Condition BRAND NEW IN ORIGINAL PACKAGING Continuous Power at 1ohm (Mono) 1301- Up Continuous Power at 2ohm (Mono) 601-800 Continuous Power at 4ohm (Mono) 451-600 Fan Cooled Yes Fuse Rating N/A Manufacturer US AMPS Max Input Gauge Size 0 Minimum Impedence 1 ohm Peak Power 3001- Up Remote Bass Knob Yes THD at Rated RMS <1% Warranty 1 YEAR Amp 2. http://www.audiosavings.com/products/Mono-Car-Amplifier/PERFORMANCE-TEKNIQUE-5000w-MONO-POWER-AMPLIFIER-CAR-AMP/ICBMSUPER.aspx5000 Watts Digital Mono Block Amplifier 1 Ohm Stable Max Output Power: 5000 WATTS @ 1 OHM 1900 watts RMS @ 1 Ohm 1600 watts RMS @ 2 Ohm 1400 watts RMS @ 4 Ohm High Current Amp More Efficiency than other Class D Amp Designs Class D Digital, Monoblock Built in low pass crossover filter Crossover Slope 24DB per Octave Input Sensitivity Control (6V to 0.2V) Bass Equalizer Control (0 - 18 dB) Bass Frequency Control Phase Control (0 - 18 0degrees) Subsonic filter Bass EQ frequency : 40 HZ - 120 Hz Bass Boost - 0 - 18 dB Wired Bass Remote Control Gold Plated Terminals & RCA 0 Gauge Power terminal High Efficiency Low Heat Emission High Damping Factor For Improved Bass hits Uses Less Energy from the car battery, so your lights don't need to dim, and you can still have a lot of power! Real 1-Ohm stability means this amp will stay cool, after pounding for days straight, with 2 dual voice coil 4 ohm subs running down to 1 ohm. Other amps may say 1 ohm stable, but this one is truly 1 ohm stable! Includes free fuse holder + bass knob Thanks For The Help
April 17, 201016 yr do not get performance teknique some guy fried his BTL with clipped power go with a USAMPS MD-2d or sundown saz 1500
April 17, 201016 yr do not get performance teknique some guy fried his BTL with clipped power go with a USAMPS MD-2d or sundown saz 1500That had nothing to do with the amp more so user error, I wouldnt get one of those amps but that is not the reason why.
April 17, 201016 yr do not get performance teknique some guy fried his BTL with clipped power go with a USAMPS MD-2d or sundown saz 1500That's not the amps fault. (user error)I would take the first one, but i think the best choice would be the AQ.(by the way, you're links don't work.)EDIT:Jay-cee ninja'd me .... Edited April 17, 201016 yr by kirill007
