I have just got a btl 18 fully loaded and am now looking for a amp and was wondering witch would be better one? :puzzled: I will be running all Knukonceptz 1/0 awg fleks wire with a big 3 upgrade with a new xs batt onder the hood so what amp would be the best thank you very much !
saz 2500 (bnib pre-order of 525) or a used saz2000 or a used saz3000 or saz3500~~
lool what is your budget and goals!!
LMAO i just noticed the title! AQ all the way though most bang for your buck! sorry about that!
Better is AQ out of the 2.
Even if the Hifonics does a couple hundred more watts, u'd never hear it!
AQ has more direct customer service and i trust them more since i've ran there amps for a couple years now.
Thank you very much you made this easy lol I will be ordering my audioque in the next week =] and finally getting to start my new build .
Hifonic amps are power hogs for what they produce compared to other good amps.
Or does anyone know if a aq3500d would be to much for my fi ?
Depends on a lot of factors such as competing/daily, box size, listening habits, goals and so on.
If you can control the volume knob, the BTL will handle that amp no problem. Does it need that amp? Nope. The power from the 2200 is more than enough for the BTL to perform awesome.
Going to need more electrical system than a one battery and a stock alt to support 3500+ watts.
Brian
Ok lol um its a 8.5 feet cubed box at 33 hertz and it would be daily but i would not crank it all the time and i listen to alot of rap thank you :woot:
  • 1 month later...
yo i got 2 saz 2000d amps for sell hit me up if ur interested u could strap both and bump that fi
352-287-1285
or
[email protected]
Edited by viperchris
If you have to ask if the btl can handle 3k+ then you shouldn't run that much. Stick with the AQ 2200D
