what about the glue inside the enclosure?? its only on the deep notes when I can feel the air move do I smell the glue. The entire inside of my enclosure is carpeted. When I said I could smell it I was basically saying my subs where really starting to break in and hit deep.
I see recones in your future.
  • Replies 84
  • Views 8.4k
  • gadgeteer123
    gadgeteer123
    I thought street beat 4 was for 15" subs. I have a 1992 buick century station wagon, with a stock 105 amp alternator, 1 extra 55ah battery, 0 gauge wire, and the big 3. the rear speakers are in there
  • gadgeteer123
    gadgeteer123
    my box is tuned to 29hz and it peaks in that area. between 30-40hz is where it hits the loudest. I have some good songs that are really loud, on my mp3 drive, should I just pick the songs that I think
  • gadgeteer123
    gadgeteer123
    I listen, to techno, euro-dance, rock, classic rock, oldies. But the best music songs that hit hard are rap. i'll post in 5 minutes what songs sound good, i have to get it from my car.
But I looked it up on google and it seemed common to smell glue on new enclosures. especially when the entire inside of mine is covered in glue. Plus I could smell the glue stronger a few days ago its starting to go away now.
Is there a difference to the smells? it doesn't smell like burning, it just smells like glue. and it is only when there is a lot of air movement.
I think yours is not a problem now if you smell burnt rubber thats a problem otherwise no. Or if your sub stop sounding the same as in output like less but if it is increasing the output your in no harm.
ya, i'm increasing in output. I'm hoping to do good at tmrw's competition. So what class should I go in if my box is 1"-2" above the window line?
If you remember, I told you to test tone it first, and try not to play something your systen might not can handle.
Rap music is not something you want to use for break in music.
I'v never smelled my coils in my system, and I compete in every show possible. SQ and SPL ...
Well i have been playing a mix of everything, from pink floyd, to lil wayne, to techno, to an occasional test tone. I turn it down every once in awhile. It has been sounding awesome so far, and gets louder every day.
Edited by Small Town Audiophile
Your going to have to find your exact peak before you can street Beat well. So tomorrow, instead of competing Street Beat, do MOD 0-1000. Ask for the disk and play track 18, it should be a sweep as long as it's the official USAC disk. Then they will tell you at what Hz was the loudest. You will get a second run, on the second run go to the corresponding track on the CD to the Hz you peaked and play it.
Once you find your exact peak, post it on the forum asking what good SB songs have the same peak. I am sure we can find a good one.
Any other questions PM me, or even better E-Mail me at [email protected]
all amps, not just your sub amp ...
USACI uses their own dics ... except in Street Beat .
I've never heard of this, maybe in SQ this is true. But I know for any MOD/Stock class it's bassed off the 4ohm output of your bass amps.
well I know I won't even have a close chance in mod 0-1000. but I guess for the practice. Hopefully i'm not laughed at....
You'd be VERY surprised as to what can do well at a show.
First place in MOD 0-1000 a few weeks ago was like a 144.x, just depends on who enters the class.
ok who knows then, I have heard of a some guy who has a xcon in a blazer with my same amp and he hit 143db I think I'll go check.
Anything is possible man.
Once you get started going to shows you will get hooked, and you will feel the need to be louder and louder. lol
what???? more hearing loss..? lol. this xcon already hurts my ears.
bassahaulic ... All amps are counted.
this is from the rules ... please read ...
USACI OUTLAW SPL GENERAL RULES
DIVISIONS:
Outlaw SPL divisions are based on the configuration of the system and vehicle. Specific
guidelines for each division will be discussed in their respective sections of this book.
POWER CLASSES: See Appendix A – Power Class and Division Limitations
AMPLIFIERS DEFINED:
One amplifier is considered one power supply, one system board, driving 1 or 2 channels. A 3-4-
channel amp would be considered two amplifiers. A 5-6-channel amp would be considered three
amps and so on. A single heat sink with more than one power supply or system board may be
considered more than one amplifier at the discretion of USACI.
A car audio system’s total wattage shall be determined by the highest manufacturer rated output
divided by the proper number to ascertain the 4 ohm power output, or the manufacturer’s 4 ohm
rating, whichever is higher. If any amplifiers rating cannot be determined, that amplifier will be
moved to the highest power class in that division until such time as a rating can be determined.
USACI reserves the right to independently test any amplifier to determine the true RMS power
rating and reclassify that amplifier as needed.
An audio system’s Sound Pressure Level will be measured using an approved sound pressure
level meter. Software for this test must be the current version of the USACI Outlaw SPL
competition compact disc. The director of the USACI event will provide a disk in case the
competitor does not have his own disk.
The SPL judge will be responsible for making sure the SPL meter is set up and functioning
correctly.
Edited by Cablguy184
Well I'll be dipped in shit and rolled in bread crumbs........ someone will know where that's from. ;)
You is correct. :)
Just to add, the rules also state that additional amps can be in the vehicle at local events, at the judges discretion.
yea, thats correct
PROPER POWER CLASS:
A competitor may not compete in a power class other than the one that his/her total system
power dictates. The exception to this would be the unlimited or “OPEN” power class
Any and all amplifiers within the vehicle under test will be included in the system’s total power.
This sum will not include the power, if any, of the systems source unit (radio, cassette tape or CD
player) unless it is actively driving a speaker or a group of speakers. All amplifiers in the vehicle
must be operational and actively used in operating the sound system during testing or be
physically removed. At local events amplifiers may be left in the vehicle provided the event
director has the ability to definitively determine the amplifier is not in use.
Competitors whose systems include amplifiers that are not manufacturer rated, are modified
internally, or not commercially available will be required to compete in the unlimited power class
of their respective division.
I went into modified 0-1000 class, and I got a 142.6db at 41hz in the passenger kick panel. I only got 3rd though.
Thats actually not bad witha box tuned low like yours is.
Seems the XCONS really like 40hz. Would prolly wang if you tuned to 40.
not bad at all! i bet it was a blast! congrats on that. did they give out trophies for 1st through 3rd? one of the usaci shows i went to they onyl gave out paper for 2nd and 3rd and 1st got a trophy... I was like WTF!! Good thing i got first, lol. but yea, congrats and look forward to seeing you at a few Wisconsin shows this year!
ya i got a sheet of paper. There was a guy with 6-15" subs in a truck in my class I forgot what subs they where, but he had a incriminator audio amp. heres a pic of his
And here is a pic of the loudest guy there. and this box is sealed. He did 159db.
WTF is that Cactus Sounds...thing? A battery?
3 batteries... and they are held in place by a bungee cord!?!?!?! lol
and the car looks like a talon or eclipse. but idk...
