Well it's not really a bass knob. It's just a knob but i want it to control my sub, the output level of it. And it is not in car audio it is home audio.
Edited by cheese20323
Oh so i get that Potentiometer and wire them to sub outs or what. And the potentiometer to the knob
But it is not just a mono amp it is like 5 channels how about like a converter or something?Or is it just too hard?
I think it should work the same way on a 5 channel if you just put a potentiometer on the RCA's.
Not really related, but in Steve's T15K Escalade build, he put a RF bass knob into the lighter socket, and made the lighter into the bass knob. I thought that looked awesome. I'm going to attempt to do it on my Explorer.
you can do that but i want it just for the bass not the whole amp? You guys get me?
I get you, does the amp have separate inputs for front, rear, and sub? If so then you should be fine, just put a potentiometer on the RCAs for the sub.
see that is the problem it just has the speaker inputs for the subs ther terminal not know rca?
I have 1 sony amp that is wire to 1ohm and gives out about 300rms. And an oldschool fisher that gives out 200rms at 8ohm and 350 at4ohm not 1 ohms stable.
No im saying i can use either of them. But im thinking of using the fisher for mids and highs and the sony for just subs? Oh i think i got it now if i use the sony and get the rca thing the P.O.T.S i can run it through there and that would be my sub level right?
alright so i got the p.o.t.s and wanted to know that all i do is cut the rca's wire them to the pots and connect everything back together and the rca would work normal. Just want to know before i ruin an rca cable.
  • 1 month later...
Can you give the link for Steve's T15K Escalade build?
Edited by The enD
Haha steve meade is a pimp, yea i like his setup and where his bass knob is, i second, i want to do that to lol
  • 2 months later...
That's just a variable frequency bass booster. That won't cut all bass out if needed.
I always recommend this.
http://mobile.jlaudio.com/products_cleansweep.php?prod_id=446
It goes inline with the RCAs, and gets power ground and ACC power. It will also boost your output RCA voltage up to 7.5 VRMS
  • 3 months later...
i have one of these.... my cousin used it and broke one of the sets of rcas, so i took some male rca's about 3 feet long n soldered em to it. plugged the males in the h/u and my reg rca's to the other. thats only cause im cheap and didnt wanna pay for a sundown one
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1770955/vpcsid/0/SFV/30046
