Posted May 6, 201016 yr Using a local CNC for now till we have $35-$60k to buy our own The entire box was cut out in about 4 min (cnc was running 2/3's speed). Andrew
May 6, 201016 yr Author this is just too cool! I'll be home late tonight finally! i'll be in touchYours gets cut tomorrow Mark!!! Andrew
May 6, 201016 yr Admin this is just too cool! I'll be home late tonight finally! i'll be in touchYours gets cut tomorrow Mark!!! Andrewsweetness! Take alot of pics for me
May 6, 201016 yr Admin at the rate you're knocking boxes out, you need one of these! hahatrust me, he is well aware of this lol
May 6, 201016 yr Thats awesome!!! Do you know the people or they just allowed you to cut the wood there? I know the operating cost for one of those has to be expensive! Either way man, if you can start cutting boxes out with that thing that would certainly be awesome!! You can start doing some crazy braces and whatever else your mind can think of!! Thanks for the help the other day, i ended up just going with a slot ported box, using the RE Audio calculator. SO what box is he building you Mark!!!
May 6, 201016 yr Admin Thats awesome!!! Do you know the people or they just allowed you to cut the wood there? I know the operating cost for one of those has to be expensive! Either way man, if you can start cutting boxes out with that thing that would certainly be awesome!! You can start doing some crazy braces and whatever else your mind can think of!! Thanks for the help the other day, i ended up just going with a slot ported box, using the RE Audio calculator. SO what box is he building you Mark!!!a prototype of one of the designs we will eventually start selling though the shop if all goes well... going to be sick!
May 7, 201016 yr Lookin good, all my measurements told me an xcon motor will fit in there....its going to be a tight fit
May 13, 201016 yr Looks great! That carpet should match the rest of my interior nicely. I suppose this means I should get off my butt and run some power wire and start finishing things up so I can give the new box and xcon a listen. Can't wait to see how the xcon does sealed.
May 13, 201016 yr They sound great sealed. I think you will be quite pleased! What amp you pushing it with?
