Figured I would start a new build log as I will be using all new speakers up front and new HU.
1998' GMC Sierra Extended Cab Daily Driver
Eclipse CD-7200 MKII
Sundown - SAX-100.4
- Oz Audio - Matrix Elite 5.25"
- Vifa D26NC05 1" Textile Dome
Sundown - SAX-125.2
-Peerless - 830520 8"
I have a mix of Second Skin and SDS sound deadening products to use on and in the doors.
Q-Forms kick panels that are already modified with MDF mounting rings and deadening attached to the back.
Doors will be modified to accommodate the new 8" midbass drivers.
Sub stage to be addressed later after the front stage is done.
Peerless 8" Midbass
Oz Audio Matrix Elite 5.25"
Vifa 1" Textile Dome Tweeter
  • Replies 65
  • Views 9.8k
  • Finally got around to building the box for my new Sundown SA-15's First the Design The Fiberglass Plate (JL Audio ISO-Plate) Test fit before primer and paint The Port after primer Port primed and
Should be a very nice set up. Nice list of stuff you got going in there. I will follow this one along.
Thank You sir!
Wife and kids are getting on me to get out of the LOUD stage and return the back seat and the back to normal .... rolleyes.gif
Ignore that shit. Rabble rabble rabble I tell ya.
I have another toy for the LOUD stuff. Going to get this build done first then build up my old Civic!
Should be a good build log, front stage looks like it will be awesome :fing34:
Should be a good build log, front stage looks like it will be awesome fing34.gif
Thanks man!
Tuned in for sure..... :popcorn: Nice list of drivers.....can't wait to see how you use them. Don't be stingy with the pics! :drink40:
Thank You! I will have the camera with me at all times!
8" Peerless and a 5.25" mid? Any reason you didn't use a more dedicated actual midrange instead of the woofer you have?
So, say something like a 4" midrange with an 8" midbass?
Personal preference from past experience with the Oz mid. I love the sound they produce on the male/female vox along with the snare drum. I used the Peerless 6.5" in a past install and liked the over all lower octave midrange/midbass frequencies it produced and felt the 8" would do a better job at midbass frequencies with the added cone size.
Tuned in to see how you mod the door for an 8. :popcorn: I just could not bring myself to cut the door up of my 05 Chevy 2500HD CC to fit the Hybrid L8's that I haven't used. Not that the L8's are needed since going to the new Blues 6 1/2.
Hopefully this weekend I get time to get started on the doors. That is if the wife doesn't find anything else for me to do! :unsure:
  • 2 months later...
This is a start to my midbass door build. Started this weekend and made good progress on the drivers door. Don't mind the oblong hole as I cut twice and measured once. :suicide-santa:
Reinforced the back of the door with MDF and fiberglass cloth
A .5" piece of MDF on the door itself to help fill in the gap between the panel and door. Dampened with SecondSkin Damplifier Pro.
An inside shot of the door with a SecondSkin Speaker Tweaker pad and more Damplifier Pro.
A side shot showing the depth of the speaker to the door
Front view of the speaker.
With the door shut! Close tolerance!
And the fleece to cover the door with
The fleece added. Will be retaining the door pocket.
Ran out of resin as this fleece absorbs a lot.
Will be adding some fiberglass cloth for strength and body filler to smooth out the wrinkles
Will be buying more resin tomorrow. :peepwall:
Nice start bro.
How are you going to finish them? Vinyl, paint, other?
Soon the real fun begins. Bondo and sanding. :suicide-santa:
There might be a future issue with the speakers clearence. You should take into mind the thickness of the fleece and fibers glass because it looks like it's a little too close.
Edited by Bobobass
Nice line up for the front stage! I don't envy you having to sand, glad my sanding time is over. Looks like you got a good start on the door pod. Waitin' for more! :popcorn:
Actually that is the floor mat that looks so close. It actually clears the door frame with ease with a little room to spare. :drink40:
Nice start bro.
Thanks,
Going to see if I can match the texture with paint and try to match the interior.
About time there was some progress on this. Keep the pitcures comin'. :popcorn:
LOL, I know, I know! :peepwall:
  • 4 weeks later...
Here are some slow but updated photos
Drivers door with first coat of resin and test fit
Close up of the drivers door. Turned out better than I thought.
Starting of the passenger door.
Picture of my Eclipse CD-7200 MKII HU.
Start of the rewiring process.
Chase my yellow lab bored.
My other two helpers Samson (Mastiff) and Harley (French Bulldog)
Chase lying down on the job.
Outside pic of my truck with tint installed.
That's it for now. Hopefully more pics later tonight.
Door Pods!! :fing34::fing34: Wanna do mine???
