Posted May 13, 201015 yr can the SSD with bp power handle 1200 RMS at 2 ohm?sorry for all the threads lolwanna make sure i get whats best
May 13, 201015 yr can the SSD with bp power handle 1200 RMS at 2 ohm?sorry for all the threads lolwanna make sure i get whats bestTry the search feature it is your friend!
May 14, 201015 yr That will come down to box size and other things, dont assume cause you get the BP Power you can throw tons of power to the sub. Look at it as a sub that is rated at 1000 rms with more a little more thermal power handling then a stock SSD subwoofer.
May 17, 201015 yr can the SSD with bp power handle 1200 RMS at 2 ohm?sorry for all the threads lolwanna make sure i get whats bestPower handling is install dependant. As for what is best, what are your goals?
May 17, 201015 yr Author can the SSD with bp power handle 1200 RMS at 2 ohm?sorry for all the threads lolwanna make sure i get whats bestPower handling is install dependant. As for what is best, what are your goals?LOUD... i think im gonna order a 15" BL and throw 1200 RMS at it at 2 Ohms. Ported box with my capacitor and in the summer going to do the Big 3 upgradejust want it to be noticeably louder than my current 2 12" MTX Jackhammers that are getting 250 RMS each. In a sealed box
May 17, 201015 yr can the SSD with bp power handle 1200 RMS at 2 ohm?sorry for all the threads lolwanna make sure i get whats bestPower handling is install dependant. As for what is best, what are your goals?LOUD... i think im gonna order a 15" BL and throw 1200 RMS at it at 2 Ohms. Ported box with my capacitor and in the summer going to do the Big 3 upgradejust want it to be noticeably louder than my current 2 12" MTX Jackhammers that are getting 250 RMS each. In a sealed boxThe BL is the right choice for that, maybe a good agm battery instead of the cap. Do the big 3 as soon as you can.
May 17, 201015 yr Author can the SSD with bp power handle 1200 RMS at 2 ohm?sorry for all the threads lolwanna make sure i get whats bestPower handling is install dependant. As for what is best, what are your goals?LOUD... i think im gonna order a 15" BL and throw 1200 RMS at it at 2 Ohms. Ported box with my capacitor and in the summer going to do the Big 3 upgradejust want it to be noticeably louder than my current 2 12" MTX Jackhammers that are getting 250 RMS each. In a sealed boxThe BL is the right choice for that, maybe a good agm battery instead of the cap. Do the big 3 as soon as you can.im looking at runnin the cap and getting the Big 3 ASAP! and when i got some spare cash im gonna invest in a yellow top to replace the capacitor
May 17, 201015 yr Don't waste your money on the cap. you won't notice any difference. Also, make sure you order the right coil configuration for your sub to wire to your amp at the power you are planning.
May 17, 201015 yr Author Don't waste your money on the cap. you won't notice any difference. Also, make sure you order the right coil configuration for your sub to wire to your amp at the power you are planning.well i have the capacitor now. i got it for free but its really good. I noticed a bit of a dfiference but when i have money i will install the Big 3 and replace the cap with a yellow top.2 ohms = Dual1 am i correct ?
